Hi guys,
(I'm not sure if this is the right subforum to post this in, but I couldn't find a better one :/)
So I'm in the process of picking out parts for my first PC build, and I was hoping to get some second opinions and a bit of help.
This is everything that I've picked out so far: http://ca.pcpartpicker.com/p/BYxMxr
Now, I'm pretty sure that all of these are good pieces of equipment, but I'm looking for confirmation.
This is going to be mainly a gaming rig, are the 980s I've picked out a good choice?
For the hard drives: I'd like to spend a little less money than that, but I would also like to have two SSDs in Raid 0. I don't need that much storage space, as this will be mainly for my OS and a few specific games. Any suggestions?
As for the motherboard and powersupply, I have no idea what I'm doing. I've picked these two arbitrarily, based on the recommendations I've seen around the internet. I'm totally open to suggestions here!
I'd also like to watercool the whole system, and I have no idea where to begin with that. In this case, a link to a forum post or maybe a video would be really helpful!
I've been watching LinusTechTips for a long time, but this is the first time I've ventured over to the forums. I like what I see!
Thanks in advance guys,
RabidBurn
(mods feel free to move my post lol)
TS3 I frequent: ts.absgaming.net feel free to join!
https://linustechtips.com/topic/367407-help-with-my-pc-build/
rabidburnYour build looks fine, i would get a slightly bigger psu maybe a 750w just to be safe. Do you plan on custom water cooling and what do you plan to cool?
CPU intel potato2 | Motherboard xpotato69 | RAM DDRPotato | GPU potato 6969 Ti | Case potato curbiide | Storage WD potato GB grey | PSU lakesonic 69 potato Watts | Display(s)69" 0.5K potato 69*69 | Cooling 4 heatpipe fried potato | Keyboard 69 key potato switches | Mouse yukon gold potato | Sound 6.9 surround potato | Operating System OS69 potato
CPU I7 5700HQ |  RAM 8gb DDR3 | GPU GTX 960M | Storage 1 TB HGST HDD | Display 15.6" 1080p IPS panel | Keyboard Steelseries RGB | Operating System Windows 10
CPU R7 3800x |  RAM 32 GB 3200MHZ DDR4| GPU RX 5700XT Ref. | Storage 1TB m.2 NVME, 2x 500GB SSD, 4TB and 750gb hdd | Display LG 32GK850F-BKeyboard Aorus K7 with reds | PSU Corsair RM750X | Case Corsair 275R | Operating System Windows 10
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975034
Are you playing at 4K? If not, then 1 980 or 1 970 will be ample. (or 290X)
 My Buyer’s Guide!
Build:
CPU: Intel Core i5 4690K Cooler: Cryorig R1 Ultimate RAM: Kingston Fury White Series 8GB SSD: OCZ 100 ARC 240GB HDD: Seagate Barracuda 1TB Motherboard: MSI Z97S SLI Krait Edition Graphics Card: Powercolor PCS+ R9 390 Case: Phanteks Enthoo Pro (White) Power Supply: EVGA G2 750W Monitor: LG 29UM67-P 29" 21:9 Freesync Sexiness Mouse: Razer Deathadder ChromKeyboard: Razer Blackwidow 2014 Headset: Turtle Beach Ear Force XP400
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975055
Okay, sounds good on the PSU, any suggestions for a specific one? As for the water cooling, I'd love to get blocks for the GPUs, and also for the CPU, those are the only two things I should need to cool right?
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975093
http://ca.pcpartpicker.com/p/JQHgxrPersonally I would go with this. Cheaper but just as good SSD, Got different ram to match the blac/reddish theme that was going on. Plus one stronger card is usally better, plus this is factory overclocked. :)
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975094
I'm not sure if I'll be playing at 4k, but I still think I'm going to go with the dual card in SLI configuration
Seriously, 2 980s are ridiculously overkill for 1440p or 1080p. Don't just buy something cuz it sounds cool to say.
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975110
Here's a high-end corsair 750w one with sleeved cables to make your build look pretty.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139042&ignorebbr=1&cm_re=PPSSGFNFSPZAYM-_-17-139-042-_-Product
And for watercooling you are correct those are the things that need cooling. Try coming up with a list of parts, if you need help just ask. EK is a good company to buy parts from.
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975137
Thanks! I love the RAM and the SSDs, but I'm not sure about the $1300 Titan X lol
I do have a 4K TV, and I might end up using it to game on
Spend a few bucks more to get a much better quality power supply. This one has a ten year warranty and is flawless.
http://ca.pcpartpicker.com/part/evga-power-supply-220g20750xr
Love it! Thanks!
Awesome!
RabidBurn
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975278
Love it! Thanks!
Awesome!
RabidBurn
The titan is factory overclocked aswell, you can get the cheaper version of it. You are paying nearly just as much for 2 980s :)
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975303
First sentence: Wait, you have 2 980s. Which is also $1300, wat? Also, if you got a Titan X you could get a lesser wattage PSU. (Still has to be good though)
Second sentence: Then yes, go with 2 980s or the Titan X (1)
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4975311
I can't decide between the superclocked Titan x posted above and the 2 980s I originally had
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4978741
Get the Superclocked Titan X.
Not only will you need less wattage on your PSU, you'll also have TONNES of bragging rights.
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4982010
But what benefits does it have over the dual card configuration?
Some games do not support SLI configuration, and the Titan X is the same, if not better than 2 980s. It will also consume less power and having the reference card is pretty sexy :P
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4983121
Well those are enough benefits to convince me!
Thanks!
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4987613
Thanks!
Oh! And I forgot to mention having a Titan X adds about 50 inches to your e-peen.
 My Buyer’s Guide!
Build:
https://linustechtips.com/topic/367407-help-with-my-pc-build/#findComment-4993464
