Hello LTT community!
I live in the top section of a duplex and my landlord has the router down in his entryway, literally as far away from my computer as possible. So here is the problem: computer lives 1 story above, and about 40 feet over from my AP/Router, with many walls and high voltage devices in between. At the moment I have a USB antenna connected to a 3' USB extension which yields marginal (at best) reception. My AP cannot be moved, nor can I run cables directly to it. I can however place an antenna directly above the AP to eliminate a lot of walls and electrical interference.
My question is this: Is there such thing as an antenna that can run a 40+ foot cable?
My understanding is that USB voltage drop over more than a few feet would render USB devices useless. Ideally I would be looking for a device that takes power from a wall plug, then sends the signal over a CAT5/6 cable that i route through my unit back to my bedroom.
Thanks for taking the time to read and all help is appreciated!
https://linustechtips.com/topic/367178-powered-wifi-antenna-cat56/
You could try finding a Wi-Fi repeater, as I THINK it does what you are looking for.
Most optimally you would run an ethernet cable to the source.
Second would straight have a better Wi-FI setup, and move the router.
But a repeater isn't terrible.
Current Desktop Build | 2200G | RX 580 4GB | 8GB RAM | CTRL | Logitech G Pro Wireless
Laptop | 2018 MBA 256/16GB | MX Master
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
"Ideally I would be looking for a device that takes power from a wall plug, then sends the signal over a CAT5/6 cable that i route through my unit back to my bedroom."
There are WiFi to Ethernet adapters like http://www.amazon.com/NETGEAR-Universal-Ethernet-Adapter-WNCE2001/dp/B003KPBRRW (first hit on google there are others)
Never tried one myself but if you have location with power and good reception to the AP where you can put a Ethernet cable to, its a better option then running long usb cables.
Could you use Powerline ethernet? is the Access point / router on the same breaker box as your pc?
Oh tatari mentioned it already.
Edit: no he didn't really need to read more thoroughly before i post.
http://www.amazon.com/TP-LINK-TL-PA4010KIT-Powerline-Adapter-Starter/dp/B00AWRUICG/ref=sr_1_1?s=electronics&ie=UTF8&qid=1431714084&sr=1-1&keywords=powerline+adapter
HOLY AMAZEBALLS THANK YOU!!
@GzeroD I didn't even think of just using a long coax cable since my Mobo doesnt have built in wifi, nor do I have a PCI style wifi adapter that uses those connections, but that would be the simple solution for those that have those connections.
@TAtari That is EXACTLY what i was looking for I just couldn't come up with the appropriate search keywords because i haz the dumb
LTT Forum solution found in less than 30 minutes!
