Hii Guys,
I want to play games in 1360x768 in all settings medium in 30-35 fps.
my specs are-
CPU_____________________i3 4150
RAM_____________________corsair vengeance 8gb dual channel
MOTHERBOARD_____________Gigabyte B85M-D3H
PSU_____________________Corsair VS 550w
And here i need A GPU,my requirements are not like |Ultra settings 60 FPS|
i just want to play every game in |Medium settings & 30-35FPS|. and i have low budget too..
so Which one should i go for a GTX 660 or 960, In india 660 and 960 are by 4000 rs diffrent...SO PLZ SUGGEST ME :-] ( u can suggest another like AMD too and you can check thier price from FLIPKART.com...........
https://linustechtips.com/topic/367088-help-me-to-choose-gpu/
GTX 660 will be more than enough to drive that resolution.
Other options (from the least powerfull card to the most powerfull one):
R7 260x
GTX 750ti
R7 265
GTX 660
R9 270
pick based on price, all of these should handle prety much 60FPS on that resolution.
https://linustechtips.com/topic/367088-help-me-to-choose-gpu/#findComment-4971064
A 750ti should be fine for what you want.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/367088-help-me-to-choose-gpu/#findComment-4971082
960. I have two 660s and they are better than a 960 but one 660 wont do you good.
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/367088-help-me-to-choose-gpu/#findComment-4971085
It would help to link us to where you're shopping and mentioning your budget.
https://linustechtips.com/topic/367088-help-me-to-choose-gpu/#findComment-4971128
