Server Build Guide Help
Solved by Sumsar,
Can I get anything decent for like $300? Like it just needs to be something good enough for RAID 10 with only 4 drives, right now there's only like max 2 - 3 people on the network so it doesn't need to be high end stuff, I would use one of my old bad desktops but it's too old to even handle Windows 7 it's only got .5GHZ so that won't work
I'd go for a Pentium G3220, 4GB ecc-unbuffered ram, a budget c222 motherboard, and pretty much any decent 80+ bronze or better PSU.
