Hi all,
I'm looking for a gaming headset that will fit comfortably on my massive head. As a guide, I find XL sized crash helmets too tight so I need a headset as accommodating as they come. I'm looking around the £50 mark but going higher isn't a big problem to save discomfort.
Thanks.
https://linustechtips.com/topic/366604-headset-for-a-huge-head/
ASTROs and Logitechs aren't bad, size-wise. The ASTRO A50 seems just right for me around the middle settings, and I wear an XL size hat. The Logitech G930 I was able to keep on mostly small settings out of its huge range. Unfortunately I hear they wear out quickly. My problem was more along the lines of signal drop-off.
https://linustechtips.com/topic/366604-headset-for-a-huge-head/#findComment-4968426
Incase you haven't bought one yet, go for the HyperX clouds 1, albeit a bit over budget. Most gaming headsets are junk and ignore 7.1 and 5.1 headsets entirely. I own a pair of G930's and i've gotten more enjoyable sound out of a €30 pair of headphones.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
https://linustechtips.com/topic/366604-headset-for-a-huge-head/#findComment-4971947
Sound quality is meaningless if you can't wear the cans. Granted it's still important, but fit comes first. Also, most wireless headsets are just automatically going to come with "7.1 virtual surround" as more of a bonus for the price than an actual selling point (despite marketing BS). I know he didn't ask for wireless, but since we're partially on the subject of the G930 I thought I would point that out.
https://linustechtips.com/topic/366604-headset-for-a-huge-head/#findComment-4972462
Logitech's are like the worst.....theres so many better options then those.. they sound awful and fall apart so quick :(
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
https://linustechtips.com/topic/366604-headset-for-a-huge-head/#findComment-4972474
HyperX cloud are in my mind your best option.
Siberia are horrible for people with big heads plus their build quality are shit.
Hardware: Intel I7 4790K 4Ghz | Asus Maximus VII Hero Z97 | Gigabyte 780 Windforce OC | Noctua NH-U12P SE2 | Sandisk Extreme Pro 480GB | Seagate 500Gb 7200Rpm | Phanteks Enthoo Luxe | EVGA Supernova G2 850W | Noctua NF12 | SupremeFX 2014 | Patriot Viper 3 16GB.
Gaming Gear: Cooler Master TK Stealth | Sennheiser PC350SE | Steelseries Rival | LG IPS23L-BN ' 5ms | Philips Brillians 144hz
https://linustechtips.com/topic/366604-headset-for-a-huge-head/#findComment-4972764
The Y.E.T.I. is in progress?Whaaat? (modding aproach&build log)->http://linustechtips.com/main/topic/355618-project-yeti-first-build/
[READ THE COC BEFORE POSTING][Check twice cut once][NZXT rules:D][Dremel is Love Dremel is Life][COOKIES ARE GREAT][LOGIC]
https://linustechtips.com/topic/366604-headset-for-a-huge-head/#findComment-4973053
