Hello,
So, I need to, (just want to), overclock my PC's CPU. The only problem is, I have no idea how to do so.
Here's my PC specifications, by the way:
OS:
Windows 8.1 PRO 64 bit.
CPU:
Intel Core i7 4770K @ 3.50GHz
Haswell 22nm Technology.
Motherboard:
Hewlett-Packard 2AF3 (SOCKET 0).
Graphics:
Sapphire Radeon R9 290X 4GB Battlefield 4 Edition - I abhor Battlefield. GTA V PC for life.
RAM:
32.0GB Dual-Channel DDR3 @ 798MHz (11-11-11-28).
Storage:
2TB Seagate ST2000DM001-1CH164 (SATA).
Optical Drives:
hp BDDVDRW CH30L.
Audio (if this even remotely matters at all):
AMD High Definition Audio Device
I guess what I'm really asking is if there's a program that I can use to do so.
Any help would be greatly appreciated.
Thanks,
-Will.
Thanks for reading!
https://linustechtips.com/topic/366124-overclocking-advice/
Hello,
OS:
CPU:
Motherboard:
Graphics:
RAM:
Storage:
Optical Drives:
hp BDDVDRW CH30L.
Thanks,
-Will.
Well you do it in the bios witch is done by the motherboard so you may want to change whatever abomination is made by Hewlett-Packard that is running that thing before you try to mess in the bios it is a Z series so it technically is possible but I wouldn't try to do it if i was starting off for my first time and it is because the bios on that board is probably the least user friendly ever.
https://linustechtips.com/topic/366124-overclocking-advice/#findComment-4959381
Also it depends on the cpu 4770ks suck at overclocking with temps
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
https://linustechtips.com/topic/366124-overclocking-advice/#findComment-4959512
