Help me guys :D
Solved by Aniallation,
Hmm so its either i3 + gtx 960 or i3 r9 280..
Thanks guys il have to decide this then.
:P
280 is better for the future then 960 imo.
Also I wouldn't get the N200 case, I have the same one and the fans have buzzing issues unless you're willing to modify the front of the case (cut metal)
http://linustechtips.com/main/topic/288580-cooler-master-n200-front-fan-noise-fix/
