Ordered a cherry mx blue filco for my mom. The box was correct, but the keyboard i opened inside was a cherry mx red keyboard.... how do i explain this to amazon. or will they not ask too much questions. their phone support is closed right now so i will try calling tommorow but just want some feedback.
Has it ever happened to anyone? Right box wrong product?
Fractal Design Define R4 | MSI x79a-GD45 | 3960X @ 4.6Ghz | Lots of EK Blocks | EVGA GTX780Ti 3GB | Corsair Dominator Platinum 16GB (4x4) DDR3 1866 | Samsung 840 Pro 512GB SSD | Western Digital Red 2TB x4 (Raid 10) | Corsair AX760 | Windows 7 Professional 64-bit
https://linustechtips.com/topic/36571-right-box-wrong-item/
I'm sure it happens.
Just tell them you received the wrong product despite it being in the right packaging, it'll be no problem.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-469264
sounds like a packing error to me, call amazon when you can they'll replace it with very little hassle. amazon have a very good customer service.
PC Builder, Engineer... BACON    Project Cobalt: http://linustechtips.com/main/topic/38058-project-cobalt-copper-piping-laser-etching-and-more/#entry489258
| NZXT Switch 810 | i5-3570k | gigabyte UD-5H | Corsair Vengeance 8gb ram | GTX 670 | 2x 60gb intel 330 series ssd's in raid 0 | 1tb seagate barracuda hdd | Corsair tx750m | XSPC razor GPU and CPU waterblocks | XSPC d5 vario pump | Thermochill Pa140.3 | phoyba 280mm radiator | Chromed Copper tubing |
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-470085
It happens more likely than you think, companies box thousands of unit every day. Something is bound to go wrong.
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-470235
Why can't Intel have made that mistake with my 3570K and given me a 3770K?!?!?!?!
Seriously: Just call them, explain that you've received the wrong product, and would like to get it exchanged for the one you ordered. They shouldn't have any problems.
15" MBP TB
AMD 5800X | Gigabyte Aorus Master | EVGA 2060 KO Ultra | Define 7 || Blade Server: Intel 3570k | GD65 | Corsair C70 | 13TB
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-470277
If you ordered directly from Amazon, then just create a return order and choose to receive a replacement.  They'll send out a new one right away, and you can return the old one anytime within 30 days.
If you ordered from an alternate seller, then you might have to go contact that seller directly.
Intel Core i7-7700K | EVGA GeForce GTX 1080 FTW | ASUS ROG Strix Z270G Gaming | 32GB G-Skill TridentZ RGB DDR4-3200 | Corsair AX860i
Cooler Master MasterCase Pro 3 Samsung 950 Pro 256GB | Samsung 850 Evo 1TB | EKWB Custom Loop | Noctua NF-F12(x4)/NF-A14 LTT Special Edition
Dell S2716DGR | Corsair K95 RGB Platinum (Cherry MX Brown) | Logitech G502 Proteus Spectrum | FiiO E17 DAC/Amp | Beyerdynamic DT990 Pro
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-470315
Don't explain to them that it has the wrong switches, just tell them that it wasn't the product that you ordered. They will gladly take it back.
| i5-4670k @ 4.2Ghz | Corsair H100i | Gigabyte Z87X-UD4H | Corsair Vengeance Pro 8GB | ASUS Geforce GTX 770 |
| Samsung 840 Pro 128GB | WD Black 1TB | Corsair AX760 | Fractal Design Define R4 Black w/ Window | Corsair AF140 x2 |
| Windows 8.1 | ASUS 23" 1080p monitor | CM Storm Quickfire Stealth- MX Blue | Logitech G9x | Logitech G930 |
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-470322
will your mom even notice? I've been under the impression that *MOST* moms wouldn't.
Daily Driver:
Case: Red Prodigy CPU: i5 3570K @ 4.3 GHZ GPU: Powercolor PCS+ 290x @1100 mhz MOBO: Asus P8Z77-I CPU Cooler: NZXT x40 RAM: 8GB 2133mhz AMD Gamer series Storage: A 1TB WD Blue, a 500GB WD Blue, a Samsung 840 EVO 250GB
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-470350
<p>I would just show them a picture with your cherry mx red keyboard by taking off one of the keycaps to show the switch and the box in order to try to get a exchange. A copy of the proof of purchase is also a good thing to attach when you are contacting them.</p>
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-472584
MİSTAKES.. they happen im sure they will fix it
He is the hero this forum deserves but not the one it needs right now.So we'll hunt him because he can take it because he is not our hero he is a silent guardian
a watchful protector A Dark Knight
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-472593
Yeah I've had it happen both ways.  Ya get something better ya keep your mouth shut.  If you get something worse you complain.  At least their process is easy.  You don't need to use the phone.
edit:  Just RMA it as wrong product and order another one.
Laws only govern the honest.
https://linustechtips.com/topic/36571-right-box-wrong-item/#findComment-472641
