My old motherboard died which was a ASUS P5GCMX 945 CHIPSET
So i bought everything new except Hard disk and DVD RW drive
My Current Config.
  • Gigabyte H81M-S1 Motherboard 1150 socket.
  • Intel Core i3-4150 4th generation processor.
  • Corsair Vengeance 4GB DDR3 RAM.
  • Corsair VS450 W PSU.
I installed everything and test booted the system. It worked properly. Then i assembled everything into the case and connected my 1TB seagate ST31000524AS HDD and the DVDRW drive. And when I booted it said no bootable device found.
Then I Checked into BIOS and in the Perpherals menu all the 4 SATA ports were EMPTY. But whenever I boot the system the hard disk led thats on the case it blinks.. and Even DVD RW drive's LED blinks. But the DVD drive tray won't eject.
I chekced for the vibrations on HDD, there are no vibrations from the HDD. I checked all the power cables and data cables,tried with other new cables that came with motherboard. No luck.
I tried connecting the Hdd to other computer, there it showed the error that said "Connected device is not compatible. Please check CSM settings in BIOS."
Please if someone could help me with this.?
https://linustechtips.com/topic/365278-hard-isk-not-spinning-up/
Make sure your power and sata cables are seating properly. If it works in neither system, I would say you have a dying/dead drive. EDIT: Try a different sata cable. I know sounds stupid but it is worth a shot.
I tried changing the cables also.No luck.
https://linustechtips.com/topic/365278-hard-isk-not-spinning-up/#findComment-4948335
If it doesnt show up in the bootable drives section in the bios. Delete everything which is selected in that section in the bios and restart. After that you should be able to select it
System: CPU - I5-6500 Motherboard - Asus B150M-A RAM - Crucial ballistix sport 2x4GB DDR4 @2400MHz GPU - RX 480 PSU - Seasonic S12II 520W Case - Aerocool Aero-800 HDD - Seagate 1TB SSD - PNY CS1311 120GB Monitor - AOC G2260VWQ6
https://linustechtips.com/topic/365278-hard-isk-not-spinning-up/#findComment-4948407
Those ports are already empty..there's nothing to delete in the bios.
https://linustechtips.com/topic/365278-hard-isk-not-spinning-up/#findComment-4953284
