Will thes GPUs Work
Go to solution Solved by Wauthar,
They can work in the same system but not doing the same task.
He not asking if they can work simultaneously, but if one of them fits in the case.
I would say so, but it's very low end (and a prebuild, if I'm not mistaken)
New to Star Citizen? Look no further!
https://linustechtips.com/topic/365262-will-thes-gpus-work/#findComment-4947704
What.. what is the point of this reply? I answered the question, even with what you said, and provided extra information that the OP might need.
https://linustechtips.com/topic/365262-will-thes-gpus-work/#findComment-4947716
Yeah its a prebuilt optiplex 390
Building the future and keeping the past alive are one and the same thing. - Solid Snake
https://linustechtips.com/topic/365262-will-thes-gpus-work/#findComment-4948124
