Hey guys!
I'm new right here and I would like to say hi to all of you!
Now I have a old laptop, single core AMD with some low end nvidia graphics card. I'm managing to convince my father to help me pay for a desktop.
Price range is from 0-850 US$. I will not be streaming or editing or rendering many videos, maybe just a few but I would like a pretty solid pc that could allow me to run CAD just in case...
I thought of an Intel I5 4590 as a processor since I don't think I would overclock the cpu, however your opinion on this is welcome!
How about red team? 8320? 8350? I like mainly open world games, like Assassin's creed and I plan on playing older games, like GTA 4 or Simcity 2013, but wouldn't mind also playing the latest games at good frame rates at good graphics.
Please could someone help me on the build? Thank you so much, btw I do not have a microcenter close by, I live in Florida.
https://linustechtips.com/topic/364831-first-build/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($235.99)
Motherboard: Asus Z87-A (NFC Express Edition) ATX LGA1150 Motherboard  ($54.99)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory  ($54.99)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($46.99)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card  ($324.99)
Case: Thermaltake Commander MS/I Snow Edition (White/Black) ATX Mid Tower Case  ($37.99)
Power Supply: Corsair CX 600W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($43.00)
24 fps for that "cinematic" feel
After a couple weeks of behavioral sciences at my school I can easily conclude my parents need to grow up.
https://linustechtips.com/topic/364831-first-build/#findComment-4942283
You could more then likely order it online or pricematch at bestbuy. Do you want Intel or AMD? Intel will be a bit better. Since you won't overclock the CPU that makes a bit easier. Whats CAD by the way?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/364831-first-build/#findComment-4942287
CAD is the Canadian Currency. Kinda like how USD is the USA currency.
https://linustechtips.com/topic/364831-first-build/#findComment-4942359
CAD is a design software, it's actual name is autocad, used to do 2D blueprints and 3D piezes(but it's not actually the best in it)
Case: NZXT phantom CPU:I5-4460 GPU:MSI-GTX1070 Gaming X RAM:2x4Gb-DDR3-HyperX fury MOBO:Asus Z97-P HDD:Toshiba 1Tb 7200rpm PSU:Sentey650W
https://linustechtips.com/topic/364831-first-build/#findComment-4942368
#DarkBlade2117 I mean AutoCad and similar programs, since I'm interested in Architecture and interior design kind of things. I would like intel, since I've only had AMD and has given me some serious problems. OC the CPU brings benefits in what tasks? Do you think an unlocked processor would be better? I could apply an OC when I need it?
https://linustechtips.com/topic/364831-first-build/#findComment-4942389
This should work fine. Cant game at ALL so maybe a 970 is best just get a card for cad if you want to cad   http://www.pny.com/Nvidia_Quadro_K620?sku=VCQK620-PB
 Just because you don't care, doesn't mean other others don't. Don't be a self-centered asshole. -Thank You a PSA from the people who do not say random shit on the internet.
https://linustechtips.com/topic/364831-first-build/#findComment-4942410
Good build, are all parts from Amazon? They apply a pretty high tax like 50-60 US$ and the Z87 board, will be able to take the OC of the cpu? I don't know, I've only looked at H97 and Z97 boards.
https://linustechtips.com/topic/364831-first-build/#findComment-4942423
All from Amazon and Newegg I think. They may be a bit off, I just listed them off the top of my head.
https://linustechtips.com/topic/364831-first-build/#findComment-4942438
Yes. i have that mobo its fine
https://linustechtips.com/topic/364831-first-build/#findComment-4942444
That's actually really cheap for this kind of card, I mean I actually don't know if I'm going to be using Autocad, but would a gpu like a 970 or 960 still be able to render the textures? I mean I can with my 256mb of dedicated Vram ;) but it's really slow, light "play like" programs of building houses and stuff.
https://linustechtips.com/topic/364831-first-build/#findComment-4942462
970 would be your best bet there then.
https://linustechtips.com/topic/364831-first-build/#findComment-4942472
Oh ok awesome! Just my father is concerned about the price, since back in the day his mobo was probably more expensive than the cpu itself, like 120 Euros... So he says rather have a good mobo that will not crash, burn or whatever.
https://linustechtips.com/topic/364831-first-build/#findComment-4942483
The mobo is great. It does not matter. WIth 200+ mobos you get "wifi and stuff" if you need wifi add one card. cheap. and the 960 should work but I would really go with the 970. Its just worth every penny. I personally went with for 170$ if you can find them two 660s in sli for around 10% less than 970 specs. but its gaming. go with the one crad (970) autocad does not support sli i don't think. it may for Quadros.
https://linustechtips.com/topic/364831-first-build/#findComment-4942527
I understand, I used to see this H97 from asus for 100$ so I thought that would have been a good buy, and I think you are right about the 970, how about the CPU? overclock or not overclock? I would like this pc to run for long until it basically becomes obsolete like my 7 year old laptop.
https://linustechtips.com/topic/364831-first-build/#findComment-4942572
Hey guys!
Yes it is a 960 but if overclocked, IT already has a high core clock. It could be just like a 970. White and Black build with a hint of blue :)
PCPartPicker part list: http://pcpartpicker.com/p/c8MrCJ
Price breakdown by merchant: http://pcpartpicker.com/p/c8MrCJ/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($219.99 @ NCIX US)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($26.98 @ OutletPC)
Motherboard: ASRock Z97 PRO4 ATX LGA1150 Motherboard  ($89.99 @ Micro Center)
Memory: Kingston Beast Series 8GB (2 x 4GB) DDR3-1866 Memory  ($68.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: Gigabyte GeForce GTX 960 4GB Video Card  ($259.99 @ Amazon)
Case: Thermaltake Chaser A31 Snow White ATX Mid Tower Case  ($69.99 @ Directron)
Power Supply: SeaSonic S12G 550W 80+ Gold Certified ATX Power Supply  ($56.99 @ Newegg)
Total: $845.41
Generated by PCPartPicker 2015-05-11 19:41 EDT-0400
https://linustechtips.com/topic/364831-first-build/#findComment-4942589
PCPartPicker part list: http://pcpartpicker.com/p/yNqQnQ
Price breakdown by merchant: http://pcpartpicker.com/p/yNqQnQ/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($235.99 @ Amazon)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($34.99 @ Amazon)
Memory: Kingston Beast Series 8GB (2 x 4GB) DDR3-1866 Memory  ($73.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($54.99 @ Amazon)
Case: Thermaltake VP200A6W2N ATX Mid Tower Case  ($92.50 @ Amazon)
Power Supply: SeaSonic S12G 550W 80+ Gold Certified ATX Power Supply  ($89.80 @ Amazon)
Total: $842.25
Generated by PCPartPicker 2015-05-11 19:38 EDT-0400
HAHA wow! how can you guys get these beast hardware for cheap? mxm... hey I really like the enthoo pro, so If I chose a cheaper ram and power supply i could buy that? and maybe squeeze in a 970 somehow? how about an I5 4590?
https://linustechtips.com/topic/364831-first-build/#findComment-4942611
i5 4460 is better
https://linustechtips.com/topic/364831-first-build/#findComment-4942621
