Hello everyone
I am looking on getting an aftermarket cooler for my CPU so I can do some mild/moderate overclocking, I have some questions I would like answered as well as a recommendation for a cooler around $100 AUD. I heard that there are some air coolers that can produce similar temps to liquid coolers at my price range, so please feel free to recommend any air or liquid coolers.
1) If my stock turbo frequency of my CPU is 4.0Ghz, and I overclock to 4.0Ghz, will the turbo boost frequency stay at 4Ghz unless I change it? Should I change the turbo boost frequency if I am overclocking?
2) What programs should I use for stress testing? I've heard that AIDA64 is pretty good for stress testing, and that prime95 is not very good for stress testing Haswell CPUs.
Here are some pictures of the inside of my rig at the moment, specs are in my signature
post-120820-0-63024600-1431346427_thumb.post-120820-0-91940600-1431346527_thumb.
Thanks in advance for your help!
https://linustechtips.com/topic/364480-overclocking-and-cpu-cooler-advice-needed/
1. Yea 4.0 to 4.0
<THE SILENT ASSASSIN>CPU(Intel i5-4690K)||COOLER(corsair H100i)||MOB(asus Maximus VII Hero ATX)||RAM(16gb of corsair vengeance)||STORAGE(Intel 530 128gb)(Samsung 850 Pro 500gb)(WD 2tb Black)||GRAPHICS(2 x Asus strix 970)||CASE(Nzxt H440)||PSU(Corsair RM750W)>http://pcpartpicker.com/b/Bbpbt6
Recomend the noctua NH-D15 for $88.89
or corsair H100i GTX for $109.99
What CPU and what board is that?
LanSyndicate Build | i5-6600k | ASRock OC Formula | G.Skill 3600MHz | Samsung 850 Evo | MSI R9-290X 8GB Alphacool Block | Enthoo Pro M | XTR Pro 750w | Custom Loop |
Daily | 5960X | X99 Sabertooth | G.Skill 3000MHz | 750 NVMe | 850 Evo | x2 WD Se 2TB | x2 Seagate 3TB | Sapphire R9-290X 8GB | Enthoo Primo | EVGA 1000G2 | Custom Loop |
Game Box | 4690K | Z97i-Plus | G.Skill 2400MHz | x2 840 Evo | GTX 970 shorty | Corsair 250D modded with H105 | EVGA 650w B2 |
What are you overclocking? 4670K? 4690K? 4790K?
Any of them can be cooled rather effectively for under $40 with a Hyper 212 Evo and a modest overclock.
If you want better the BeQuiet Dark Rock series is good as is the Noctua ND15.
You can always go AIO with a Corsair H105 or H110, but a 120mm H80 would work just as well.
Lots of options!
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
1. Yea 4.0 to 4.0
Ok cool so if I overclock to 4.0Ghz should I turn up the turbo boost frequency or leave as is? Do people adjust it when they overclock?
Cool I will check those out thanks!
for best overclocks get a liquid nitrogen cooler
What do the cheapest liquid nitrogen coolers out there cost? they sound pretty expensive and I don't really feel comfortable handling liquid nitrogen.
Like I said in OP the info is in my signature but it is a 4690k and Gigabyte Z97M-D3H.
and something else I would suggest is to dust out your case, I notice a little bit of dust on your pictures
dust affects cooling performance :P
I'm going to do some dust removal when I get my new cooler
Lots of options!
I'm overclocking a 4690k. I was looking at a 212 evo but since the temperatures in summer can get up to 35c (95) I wanted something a bit better. Thanks for the names of those coolers I will look into them
-snip-
Sorry, the MOBO color threw me off and I didn't see the heatsink under the wiring :blush: To directly answer the OP,
1) Your Turbo boost is an Intel feature that does not boost all the cores of the CPU, only one core is boosted to Intel's Turbo spec'd 3.9GHz. When you overclock the CPU you have a few options depending on your board. Either fully manual ratio control per core, "optimized tuning" that the board will choose to enable on its own (along with other parameters -including voltage), or flat matching core settings.
Out of the 3 options I would only recommend matching all core settings, meaning every core will be set to the multiplier of your choosing. Whichever option you decide to go with Intel Turbo Boost is forgone, some boards will still show it as "enabled" but it has nothing to do with how your CPU is actually being overclocked. If you are referring to a modular set of speeds the CPU will operate at, those are C-states, a power saving feature of the chip. When the CPU is at idle it will downclock automatically, then when it comes under load it will run at the speed you set. Voltage should be set at manual for all stress testing and will be non-variable, but you can move it to adaptive once you are 100% done with synthetic benchmarks, then the voltage will vary within a range you set -similar to how the CPU downclocks/upclocks under load.
2) Intel XTU, AIDA64, Cinebench R15, and 3DMark are all good programs for preliminary stress testing. Those coupled with some real world tests that you devise based on what you do everyday would iron out any potential instability. I usually run all of those programs listed + multiple Flash players, video encoding suites, and games.
As far as AIO's go I would recommend the H105 or Kraken X61, just make sure they will fit the N500 (I see the Seidon 240m would fit according to Coolermaster's website, it's also an option). If 35C are your ambient temps you'll definitely want a 240mm rad over a 120.
