So I recently bought a 7970 off ebay  to go along with my other 3 year old 7970 just to get more performance in games and I tried the setup with multiple games such as GTA V, Crysis 3, Battlefield 4, Dragon Age Inquisition. What I noticed was that my CPU usage would jump 10%-15% higher than just using a single card and would create a bottleneck for my GPU's therefore not letting them hit max load. I was wondering if this was normal for other Crossfire users or I just might have a bad setup.
My specs:
i5 3570k @ 4.6 GHz
ASrock Z77 extreme4 motherboard
16 GB DDR3 1600MHz
2x7970 in Crossfire
https://linustechtips.com/topic/364223-cpu-usage-is-higher-when-using-crossfire/
In an ideal situation, BOTH the CPU and GPU should be at 100%.
If your CPU has increased since adding a second graphics card, then your GPU WAS the bottleneck.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
