I normally use the black industrial Noctua fans. I finally bought my first Nf-f12. The Y cable that comes with it is missing a pin where fans connect. Pretty sure this is broke but since it is my first Noctua Ycable I just wanted to be sure.
post-191431-0-09426300-1431286727_thumb.
The one on the left has 4 pins the one on the right has 3.
I7 5820k, Asus X99 Sabertooth, 980Ti Classified, 32gb Gskill Ripjaws 4, Corsair Rm1000i, Samsung 950 Pro, Custom Loop Xspc Cpu Block Ek Gpu Block, Windows 10, Define S. Acer Predator XB271HU
https://linustechtips.com/topic/364106-noctua-y-cable/
It's not broken. They are like that on purpose.
The projects never end in my line of work.
CPU: Dual Xeon E5-2650v2 || GPU: Dual Quadro K5000 || Motherboard: Asus Z9PE-D8 || RAM: 64GB Corsair Vengeance || Monitors: Dual LG 34UM95, NEC MultiSync EA244UHD || Storage: Dual Samsung 850 Pro 256GB in Raid 0, 6x WD Re 4TB in Raid 1 || Sound: Xonar Essense STX (Mainly for Troubleshooting and listening test) || PSU: Corsair Ax1500i
CPU: Core i7 5820k @ 4.7GHz || GPU: Dual Titan X || Motherboard: Asus X99 Deluxe || RAM: 32GB Crucial Ballistix Sport || Monitors: MX299Q, 29UB65, LG 34UM95 || Storage: Dual Samsung 850 EVO 1 TB in Raid 0, Samsung 850 EVO 250GB, 2TB Toshiba scratch disk, 3TB Seagate Barracuda || PSU: EVGA 1000w PS Platinum
https://linustechtips.com/topic/364106-noctua-y-cable/#findComment-4932536
Ok thanks guys.
kNMjsp6.png\\
This is why, if you were curious.
https://linustechtips.com/topic/364106-noctua-y-cable/#findComment-4932562
kNMjsp6.png\\
Yeah I was thanks for that. Makes a lot of sense when you see the diagram.
https://linustechtips.com/topic/364106-noctua-y-cable/#findComment-4932585
