Sli 970's is overkill for 1080p gaming unless you are going for 144HZ.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/363821-good-parts/#findComment-4928976
CPU Cooler: NZXT Kraken X61 106.1 CFM Liquid CPU Cooler  ($129.98 @ NCIX US)
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard  ($112.99 @ SuperBiiz)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive  ($117.88 @ OutletPC)
Video Card: Gigabyte GeForce GTX 970 4GB WINDFORCE Video Card (2-Way SLI)  ($349.99 @ Amazon)
Total: $1601.58
Generated by PCPartPicker 2015-05-10 05:39 EDT-0400
Less money, better CPU cooler same performance.
If you a single card for 1080p though you could always go with a single 980 and add another one later down the road but i know that 980s in greece are even more expensive( near 700) so the 970 is an excellent choise. Dual 290s is also a viable option.
https://linustechtips.com/topic/363821-good-parts/#findComment-4929100
Nice Build! I don't know though. I kind of need the i7 considering i'm using too much of my Illustrator and After Effects. I picked the mpower series z97 board from msi originally because of the overclocking capabilities. In any case thanks I got some good advice out of your build. I kinda want to know if the i7 is needed... It could be an overkill.
https://linustechtips.com/topic/363821-good-parts/#findComment-4929642
Then keep the i7. Though i would go with a cheaper z97 motherboard as the mobo doesn't affect overclocks anymore. A 100 euro z97 board will do the same job as a 300 euro z97 mobo.
Also quoting helps other people to know that you replied on their post.
https://linustechtips.com/topic/363821-good-parts/#findComment-4929927
If you want a great overclocking board then the Gigabyte SOC boards are very good.
http://pcpartpicker.com/part/gigabyte-motherboard-gaz97xsocforce
http://www.kitguru.net/components/motherboard/luke-hill/gigabyte-z97x-soc-force-motherboard-review/
Also here is a better power supply - http://pcpartpicker.com/part/evga-power-supply-220g20750xr
https://linustechtips.com/topic/363821-good-parts/#findComment-4929933
