Hi,
My question is,
Think of this: if a hard drive that is set to IDE mode... Then i remove it to install win8 on ssd.
I install a SSD on ahci mode.
When im in windows on the ssd, will that hard drive still be detectable that was on IDE? In the My computer?
Err I think so, if you're using the mechanical drive as storage I think you'll be OK though I'm not 100% sure because I've not really had much to do with installing and playing around with SSD's yet but it should still be detected if it's a secondary drive.
DESKTOP - Motherboard - Gigabyte GA-Z77X-D3H Processor - Intel Core i5-2500K @ Stock 1.135v Cooling - Cooler Master Hyper TX3 RAM - Kingston Hyper-X Fury White 4x4GB DDR3-1866 Graphics Card - MSI GeForce GTX 780 Lightning PSU - Seasonic M12II EVO Edition 850w  HDD -  WD Caviar  Blue 500GB (Boot Drive)  /  WD Scorpio Black 750GB (Games Storage) / WD Green 2TB (Main Storage) Case - Cooler Master 335U Elite OS - Microsoft Windows 7 Ultimate
Once you have your BIOS set to AHCI, when you plug the hard drive back in after the installation, it should see and read the drive through AHCI as well.
Either way, it doesn't matter. AHCI and IDE are just the difference of legacy support and not. It shouldn't affect speed or anything since hard drives top out around 150MB/s. Just make sure your SSD is pulling around the advertised speeds and you should be fine, at least in my own experience I have been.
yes, but you could not boot from this HDD, you can ONLY use the HDD when you are already loaded in windows through an SSD or similar
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
