I hope this is the right place to show off...  anyway, what do you guys think?  (i had to ask soo many questions on this website to get this build just right.  best tech website i have ever seen)
http://pcpartpicker.com/p/6g8PD3
also, the build is nothing special, it is my first build after-all.
The Canadian Version Of Everything
-Made In Canada
https://linustechtips.com/topic/363457-my-first-pc-build/
How much money do you have and what will you be using it for?
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924394
the money is not fully determined yet, i will most likely have the cash for this PC by july.  the price limit we will say is 1.5k... and i will be using it mainly for gaming
-Made In Canada
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924408
I think that your build looks very good so I would go a head and get it. B)
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924411
i say mainly because i may try streaming, but im not making any big plans for that.  for now, yes, just gaming.
Well the I7 should be good for streaming games all though you may want to upgrade to 32gb of ram if you are streaming.
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924423
Check out this build.
CPU Cooler: Thermalright TRUE Spirit 140 POWER 73.6 CFM CPU Cooler  ($46.99 @ SuperBiiz)
Motherboard: EVGA Z97 FTW ATX LGA1150 Motherboard  ($119.99 @ NCIX US)
Storage: Sandisk Ultra II 240GB 2.5" Solid State Drive  ($98.74 @ Newegg)
Video Card: PowerColor Radeon R9 290 4GB TurboDuo Video Card (2-Way CrossFire)  ($222.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer  ($19.49 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($86.88 @ OutletPC)
Case Fan: Noctua NF-P14s redux-1200 PWM 64.9 CFM 140mm  Fan  ($20.39 @ OutletPC)
Total: $1442.04
Generated by PCPartPicker 2015-05-09 14:22 EDT-0400
"Rawr XD"
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924433
Total: $1442.04
I would get rid of those case fans and the dvd writer and get a copy of windows of G2A and with the money you have saved get a I7.
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924456
You'll want the case fans with two 290s.
The DVD writer is OP's choice but $20 is a negligible difference
I don't exactly trust G2A to give you a key from a seller that's 100% legit and not some MSDN nonsense that'll end after a few months.
"Rawr XD"
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924485
The case does come with fans, if the op wants to have his optical drive then he might as well have it and I would try to find any other cheaper way of getting windows as it is super expensive.
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924501
It only comes with two (one front intake, one rear exhaust) which is less then optimal for a rig with two 290s and especially if OP plans to overclock CPU as well.
There's ways of obtaining Windows though... "unofficial" means that OP can consider but obviously legit way is the legal way.
"Rawr XD"
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924509
He doesn't need an i7, the i5 will more than likely be enough if he does end up streaming. I would keep the fans, they're good quality, and the static pressure is great to have for directed airflow. Not to mention that they're the most well-rounded fans Noctua has.
Also, I refuse to trust G2A, due to the sketchy past.
FX-8350 | GA-990FXA-UD3 | G.SKILL 2x8GB 1600MHz | 1TB WD RE4 | CM Hyper 212 EVO | MSI R9 290x Lightning | Corsair AX860i | Silverstone FT05B-W
Pentium G3258 | MSI Z97 PC Mate | G.SKILL 4x4GB 1066MHz | 500GB Samsung 2.5" | Stock cooler | Pending GPU | EVGA 500B | Antec DF-35
GoPro Hero 3 Silver | Netgear R7000 Nighthawk with DD-WRT | HP Officejet Pro 8610 | Canon iP110 | AudioTechnica ATR2500 USB
Downdraft cooler for mITX board (new build) | Desk mount mic stand | Pop filter | Anti-vibration mount for microphone | mITX case | 3rd monitor (matching existing 23.1" | Intel Core i7-4790K (for mITX build)
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924526
I saved you $200
CPU: Intel Xeon E3-1230 V3 3.3GHz Quad-Core Processor  ($241.95 @ SuperBiiz)
Motherboard: Asus Z87-A ATX LGA1150 Motherboard  ($81.98 @ Newegg)
Storage: Crucial MX100 128GB 2.5" Solid State Drive  ($69.00 @ B&H)
Video Card: Sapphire Radeon R9 290X 4GB Tri-X Video Card (2-Way CrossFire)  ($299.99 @ Newegg)
Case: Phanteks Enthoo Pro ATX Full Tower Case  ($99.99 @ Amazon)
Total: $1337.76
Generated by PCPartPicker 2015-05-09 14:39 EDT-0400
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/363457-my-first-pc-build/#findComment-4924562
