Hi,
I recently just bought a Msi Nvidia GTX 970 4G and I would honestly have expected higher frame rates. Could it be my CPU? Here's a run down of my build.
CPU - AMD FX 6300
GPU -Msi Nvidia GTX 970
Mobo - Asus M5A97 LE R2.0
RAM - 16GB HyperX Savage CL9 1866Mhz
PSU - 500W 80+
HDD - 1TB WD Blue
SSD - 120GB Kingston
As for screens, I have an LG IPS 24inch monitor and a AOC TN monitor as well (dual monitor setup)
I play games such as League of Legends, Aion, CS:GO. I also stream as well.
On League of Legends with nothing on e.g. I'm not watching any streams I get max 170-200 FPS
When watching a stream and playing league, I get around 100-150 FPS.
When I stream I get around 80-90 FPS.
On Aion I get a solid 60 FPS that fluctuates upwards by +5 and -3 down. When streaming, I get about 40-50 FPS on Aion.
What is the problem here? Honestly I expected a lot more from this "beast" GTX 970.
https://linustechtips.com/topic/363006-why-are-my-frames-so-low-fps/
Definitely a CPU bottleneck. Grab a 4690K.
Prometheus (Main Rig)
CPU-Z Verification
Laptop:
Intel Core i3-5005U, 8GB RAM, Crucial MX 100 128GB, Touch-Screen, Intel 7260 WiFi/Bluetooth card.
 Phone:
 Game Consoles:
Softmodded Fat PS2 w/ 80GB HDD, and a Dreamcast.
If you want my attention quote my post, or tag me. If you don't use PCPartPicker I will ignore your build.
Welcome, to the wooooooooorld of bottlenecking!
Get a new CPU or be like me, the 2x DSR cool guy that fixed his CPU bottleneck with higher resolution
But you aren't even going below 60fps, so who cares if it's not lagging? the difference between 65fps and 900fps on a 60hz panel is nothing
EDIT: I re-read that apparently you are lagging. Try using the NVENC to stream, which will move some load from your midrange CPU to your high-end graphics card. That should give you a very generous FPS boost while streaming. (OBS->settings->encoding->Nvidia NVENC, if you use xsplit I truly am sorry for you)
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
#CPUBottleneck!
Get a new CPU... That 970 most likely isn't even trying to go to it's full potential in most games and tasks... Look at low end i5s. :)
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
Like everyone else has said, CPU bottleneck, gotta upgrade it to feel the real power of the 970.
PC Specs:
CPU: i7-9700k  | Motherboard: Gigabyte Z390 Aorus Elite | RAM: 16GB's Team T-Force Vulcan 3000MHz | GPU: Zotac GTX 1070 8GB AMP! Edition  | Storage: 500GB WD Caviar Blue | 1TB WD Caviar Black | Crucial BX200 240GB SSD | OS: Windows 10 64-bit  | PSU: EVGA SuperNOVA G2 650W 80+ Gold | CPU Cooler: Noctua NH-D14 | Mouse: Logitech G502 Proteus Spectrum Headphones: Sennheiser HD 598 Special Edition's, HD 598 Cs | Keyboard: CM Storm QuickFire XT MX Blues Monitors: Acer GN246HL 144Hz, Acer G226HQLBbd 60Hz | Case: Phanteks Enthoo Pro.
Cheers for the response guys, appreciate it. I'm looking to upgrade to the i7 4790k soon with a msi gaming 5 mobo soon.
And thanks for the NVENC help, I'll see how that works for me.
An i5 will do plenty for gaming. i7 is not necessary.
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
For streaming though,  multithreading can help quite a bit.  I would only recommend it though if you were actually making decent money from said streaming.
Oh right, I didn't see the streaming part. An i7 will do nicely for streaming.
An i5 is enough for streaming, and gaming performance really doesn't improve that much for the ~$100 more to spend, but for streaming, it results in less dropped frames and probably less stuttering.
If you stream quite a bit (right above), then yes, go for the i7.
Gaming rig:
i5-4670k, H100i, MSI Z97 SLI, Vengeance DDR3-1600 2*4GB, 840 EVO 250GB, Barracuda 1TB, GTX 780 Ti, 450D, CX750, VG248QE
Workstation:
Xeon E3-1231 v3, NH-U14S, Asus Z97-PRO, Ballistix Sport DDR3-1600 2*8GB, 840 EVO 250GB, 2*WD Red 2TB (RAID 0), GTX 780 Ti, Define R4, AX760, VS229H-P
