I don't know whats going on with my cpu but at idle (nothing running except for hardware monitor) its goes from its lowest speed of 1.3 and ramps up and down to .1 ghz faster than you have it clocked at... So like at my overclock at 4.3 its would go from 1.3- 4.4 and do that over and over again. And the temps where as if it was at 100% load. Even though the usage said about 20% which is normal..
Its an fx-4130 stock at 3.8
Is it just dying or what?
https://linustechtips.com/topic/362783-cpu-problems/
Is your motherboard a Gigabyte 990XA-UD3 by any chance?
Intel i7 3770K [] Asrock Z77 Extreme 4 [] MSI R9 290X 4GB [] 16GB  G.SKILL 2133Mhz [] Crucial MX100 256GB [] WD Black 1TB [] XFX Pro 850W [] Fractal Define R3 [] Func MS-3 R2 [] Corsair K60 []
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4916882
When my cpu is underload (amd fx-6300 @4.2GHz) it also changes the clock speeds. Mine go from 3GHz to 4.2GHz. Thats normal for under load, but very strange if it happens while idling.
Which program do you use to messure your clock speeds? Also, are there any background programs which use alot of cpu recources?
System: CPU - I5-6500 Motherboard - Asus B150M-A RAM - Crucial ballistix sport 2x4GB DDR4 @2400MHz GPU - RX 480 PSU - Seasonic S12II 520W Case - Aerocool Aero-800 HDD - Seagate 1TB SSD - PNY CS1311 120GB Monitor - AOC G2260VWQ6
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4916897
I am using harware monitor.. And my clock speeds change rapidly very fast. And all of cores change at different rates and they are never constant
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4916913
Edit, I understood something wrong. Nevermind  <_<
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4916926
If it's holding steady at 4.3Ghz (or whatever you have it clocked at) under load then you have nothing to worry about. Use CPU-Z btw.
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4916943
I have cpu z too   its the same. But at idle its ramping up and making lots of heat as iff it was at full load. I just want to know whats wrong..
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4917009
The CPU ramping up and down is normal -- it is one of the power-saving features now implemented in many of today's modern CPU's.
What are your idle and load temperatures; can you post a screen capture showing those values?
What CPU cooler are you using? stock? aftermarket?
What is the rest of your system specifications (other than the FX-4130 and Gigabyte GA-78LMT-USB3 motherboard that you have already mentioned in your posts)?
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4917102
You said it yourself, The CPU is at around 20% usage. Just because the clock speed is at the highest point doesn't mean it's under full load. I have my 2500K at a static 4.5Ghz at the moment and of course it's running a slight bit warmer idle than it would be if i was letting it downclock itself with power saving features but not anywhere near as hot as it would would if it was under an actual load at 4.5Ghz while gaming for example.
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4917160
I'm not stupid.. I know things change. They are ramping up to full speed and all the cores are changing independanly. And my cpu didn't do this before..
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4917217
Check what you have running in the background that is causing this.
Otherwise, please answer my other questions, so WE can see what system configuration we are trying to troubleshoot here.
EDIT: Took a quick look at your profile, so I got a glimpse of your system configuration; cross that off the list. For the people trying to help
CPU: FX-4130 (Tray / OEM; CPU only)
CPU Cooler: Cooler Master Hyper 212 EVO
Motherboard: Gigabyte GA-78LMT-USB3
Memory: Crucial Ballistix Sport 8GB (2 X 4GB) --  BLS2KIT4G3D1609DS1S0
Storage: 1TB WD Cavair Blue
GPU: Gigabyte WindForce R9-270X 2GB
Case: NZXT H440
A few Corsair SP 120 case fans
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4917282
My temps at load are at 30-38 C    thats with an overclock.. at idle the are around 8-9 C (yes they are really low)
It is cooled with a hyper 212 evo with the sp 120mm performance fans running full speed all the time
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4919808
What program are you using the monitor CPU temperatures?
Can you post a screenshot of it running?
8*C ~ 9*C is not correct...when Kansas is about 24*C high, and 18*C low at the moment (Google weather :) ).
Temperatures below ambient / room temperature...goes beyond the physics and math that runs our world -- that is unless you are using sub-zero cooling (but you are only using a Hyper 212 EVO).
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4919834
Where the hell do you game? A meat locker?
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4919837
Wha? I don't even... How?
I've never seen an FX of any kind run that low. Ever.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4919839
I don't understand it but it works
I have triple 120mm fan intake too. And I don't know how to take screen shots..
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4919857
This is me... I did this just for you guys..
https://www.youtube.com/watch?v=rmJ7ST8qBzE
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4919987
Bingo!
Thank you for the video. (BTW, screen capture -- use the "PrtScn" key on your keyboard)
HWMonitor's "Temperature" --> "Package" gives incorrect readings when the system idle.
Rum a stress test, like AIDA64 or Prime95, then it will give more accurate readings.
If you go to 0:55 in your video, with Gigabyte motherboards, "Temperatures" --> "TMPIN0" (or TMPIN1) is your CPU temperature.
Your FX-4130 is sitting at ~31*C.
The other two is motherboard temperature and CPU/NB temperature (I don't recall which is which exactly for Gigabyte boards).
For comparison, here is HWMonitor for my FX-8350.
As you can see, my "AMD Fx-8350" --> "Temperatures" --> "Package" is not correct either; it is showing 18*C.
It seems that with ASUS motherboards, HWMonitor actually labels which temperature reading is which (i.e. "CPU," "Mainboard," "SB,"...etc)
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4920041
Bingo!
My Asus H97M-PLUS didn't have everything specifically labelled... Think it's for like AM3/AM3+ boards... Especially seeing AMD has terrible sensors on their cpus.
Senor Shiny: Main- CPU Intel i7 6700k 4.7GHz @1.42v | RAM G.Skill TridentZ CL16 3200 | GPU Asus Strix GTX 1070 (2100/2152) | Motherboard ASRock Z170 OC Formula | HDD Seagate 1TB x2 | SSD 850 EVO 120GB | CASE NZXT S340 (Black) | PSU Supernova G2 750W  | Cooling NZXT Kraken X62 w/Vardars
Secondary (Plex): CPU Intel Xeon E3-1230 v3 @1.099v | RAM Samsun Wonder 16GB CL9 1600 (sadly no oc) | GPU Asus GTX 680 4GB DCII | Motherboard ASRock H97M-Pro4 | HDDs Seagate 1TB, WD Blue 1TB, WD Blue 3TB | Case Corsair Air 240 (Black) | PSU EVGA 600B | Cooling GeminII S524
(Deceased) DangerousNotDell- CPU AMD AMD FX 8120 @4.8GHz 1.42v | GPU Asus GTX 680 4GB DCII | RAM Samsung Wonder 8GB (CL9 2133MHz 1.6v) | Motherboard Asus Crosshair V Formula-Z | Cooling EVO 212 | Case Rosewill Redbone | PSU EVGA 600B | HDD Seagate 1TB
DangerousNotDell New Parts For Main Rig Build Log, Señor Shiny  I am a beautiful person. The comments for your help. I have to be a good book. I have to be a good book. I have to be a good book.
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4920069
Hmm...it may with certain motherboards only.
Here is my ASUS Maximus VII Hero (with an i5-4690K). It has temperature readings labelled as "Mainboard," "CPU," and "TZ01" (which I am unsure what that is).
AMD Ryzen 9000 Rig
AMD Ryzen 5000 Rig
  • AMD R7-5800X
https://linustechtips.com/topic/362783-cpu-problems/#findComment-4920141
