First of all I play a lot of early access games. (Just like the concept of small production non main stream AAA games)
Most of which don't support SLI a few do but I seem to get about the same or better FPS in some cases.
For example BeamNG.Drive which I can do about 60 fps.
I want stick with Nvidia because of G-Sync.
I currently have 2 GTX970's  I was thinking of doing a single 980 or Titian X.
Would a Titian X be overkill for 1440 at 144hz? and or for my 4790K system with 16gb of ram.
Either way I would sell my 970's to cover some of the cost.
Would I be off keeping my 970's or upgrading?
https://linustechtips.com/topic/361712-single-card-solution-to-replace-sli/
If you need a single card, I'd recommend the 980, or possibly the 980Ti
Having problems with your fresh Windows 10 install? PM Me!
Windows 10- Want To Disable Telemetry, Disable Cortana, Disable Windows Updates? Look at my guide HERE
LTT Beginners Guide  | Community Standards | TN&R Posting Guidelines
I would keep the 970's
if you must switch I would go for the titanX or wait for the 980ti.
the 980 is just too much of loss when sli works and too little of a gain when it wont work to be worth switching, at least in my opinion.
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
If you can afford it, go for the titan x xD Then you can brag about it to your friends and such, and its the most powerful single gpu card out there atm, so yeah...
980 and save some cash?
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
For now, you should keep the 970s. Are they performing bad at the stated resolution? Or are you planning on buying a monitor with that resolution?
Not really performing bad at that resolution just sometimes performs better with SLI disabled.
Get fastest gpu you can afford plan and simple. If you can however wait the 980ti looks good if its released.
This is not always the best advice. Especially when someone is thinking about upgrading in the same product generation as their current setup.
Titan X is the only single GPU equivalent to 970 SLI.
Not equivalent, better.
Its roughly equivalent to 980 SLI.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
Are you high?
Are you high?
No? I saw the titan x benches.
It loses to a 980 combo by about 7fps.
In terms of raw performance, SLI GTX 980 is certainly the faster option. However the benefit of the Titan X is that it would give you around 70% of the performance of SLI GTX 980
https://forums.geforce.com/default/topic/819571/gtx-980-sli-vs-titan-x/
Nvidia Dissagrees with you.
