Can I fee double my download speed by buying a WiFi card and using that and Ethernet together?
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/360442-double-internet-speed/
I would get a new modem.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/360442-double-internet-speed/#findComment-4886998
Why?
https://linustechtips.com/topic/360442-double-internet-speed/#findComment-4887006
It all depends on your network set up and internet connection.
If your using an ancient 10mbit router and have a 20mit+ internet connection then yes. otherwise it is unlikely.
What are you using now, we need to know this to see if it can be improved without an isp upgrade/change
System CPU : Ryzen 9 5950 doing whatever PBO lets it. Motherboard : Asus B550 Wifi II RAM 80GB 3600 CL 18 2x 32GB 2x 8GB GPUs Vega 56 & Tesla M40 Corsair 4000D Storage: many and varied small (512GB-1TB) SSD + 5TB WD Green PSU 1000W EVGA GOLD
You can trust me, I'm from the Internet.
https://linustechtips.com/topic/360442-double-internet-speed/#findComment-4887025
Century link internet, and an ancient but 100mbps router.
https://linustechtips.com/topic/360442-double-internet-speed/#findComment-4887031
Does century link do Fiber in your area ?
Tried 2 cities in Montana. both only had access to older dsl Upto 15 Mbps. So your probably handicapped by your ISP's end
https://linustechtips.com/topic/360442-double-internet-speed/#findComment-4887055
Yeah, probably. I hate century link.
https://linustechtips.com/topic/360442-double-internet-speed/#findComment-4887419
They seem to be expanding their fiber systems in several states. So depending on how close you are too a city or at least not in a rural area. they will probably get too you... eventually.
https://linustechtips.com/topic/360442-double-internet-speed/#findComment-4887467
