Overclocking questions!
Go to solution Solved by Jumper118,
Okay, I just want to be sure before I attempt anything.
as long as it doesn't go over 62c, you can overclock it as far as you like.
To begin, I am a complete "newb" in the area of overclocking, so please excuse my lack of knowledge.
I have an AMD Fx-8320 which runs stock at 3.5GHz, and take note that however crappy it may be I still have the stock heat-sink.
My question is, if the Fx - 8350 comes clocked at 4GHz stock out of the box shipped out with the same heat-sink, would there be harm in up-clocking my 8320 to 3.8 - 4GHz, all while staying within safe temperatures until I upgrade the cooler?
Furthermore, if this small overclock wouldn't be a problem, could someone point me in the right direction towards a good / safe overclocking guide?
https://linustechtips.com/topic/360384-overclocking-questions/
You could overclock the 8320 to 4GHz if the two coolers are the same.
https://linustechtips.com/topic/360384-overclocking-questions/#findComment-4886186
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/360384-overclocking-questions/#findComment-4887096
