Best mousepad for CS:GO (Razer Deathadder)
HowToGaming
Go to solution Solved by beach_boy98,
Does this help?
I have a Razer Deathadder and my current mouspad (Razer Goaliathus Control) is too small. I am looking in to buying a new one.
I am hearing good things about the SteelSeries QCK Mousepad, but i'm not sure
Suggestions would be greatly appreaciated, thanks in advance.
"My signature is in Comic Sans, and therefore I am cool" - Anonymous
CPU: i7 4790K @ 4.2 Cooler: Be Quiet Dark Rock Pro 3 Motherboard: ASUS Sabertooth x97 RAM: 16GB DDR3 Ram GPU: EVGA GTX 770 Superclocked SSD: 256GB SSD (OS) HDD: 1T 7200RPM Case:BitFenix Coloussus Venom Edition PSU:EVGA 850W Gold Fully Modular OS: Windows 8.1 Pro 64Bit
I got given the Steel series one with the big Dota logo by a friend.. I have never played dota so means nothing to me, But its been a really awesome mouse pad so far, its even had tea split on it.
Redstone:
i7-4770 / Z97 / GTX 980 / Corsair 16GB  / H90 / 400C / Antec EDGE / Neutron GTX240 / Intel 240Gb / WD 2TB / BenQ XL24
Obsidian:
MSI GE60 2PE i7-4700HQ / 860M / 12GB / WE 1TB / m.Sata 256gb/Elagto USB HD Capture Card
Razer Deathadder Chroma / Razer Blackwidow TE Chroma / Kingston Cloud2's / Sennheiser 429 / Logitech Z333
Does this help?
It's even from LinusTechTips! How cool! Thanks for the vid :)
I've had cat vomit on my mousepad and it's still doing the job, it's just too small for me :/
I'd personally go for the Corsair MM200E, amazing mouse pad :3
NCASE M1 i5-9600k  GTX 1080 FE Z370N-WIFI SF600 NH-U9S LPX 32GB 960EVO
I'm a self-identifying Corsair Nvidia Fanboy; Get over it.
Np get a nice mouse pad.
Any mousepad will do. The bigger the better if you paly on low DPI/Sensibility. If you just want a brand on it get one from like SteelSeries, or Corsair etc.
QcK is fantastic. I love mine.
I will go with a QcK. OFC you could go with a goliathus extended wich is like huge but I dont know if they have the extended control version. (theres speed and control)
CPU: AMD FX 8350 | GPU: AMD R9 270 Windforce | MOBO: ASRock 990FX Extreme 3 | RAM: Kingston HyperX 8GB | Case: X Predator X1 |CPU COOLER: Hyper T4
NAZIS WILL RISE.
Many CS:GO professionals use the QcK, it's a great mousepad
The Steelseries DeX is the best mat I've ever used, but unless you can get it on offer it's really expensive.
It's something I use everyday and contact, so I wasn't willing to buy some cheap crap, and don't regret it at all.
I second this. Best mat I have ever used.
