hey i am working a on scrap yard build and i am wondering will a 2 quad core e6600 work on the curent mother board i hav here it use to have a penium 4 on it and i am working on a nice scrap build i am also working on getting a new power susply and a new gpu so any help on what to get for would be help full the pics bellow are of the mother boar IMG_0515.jpgIMG_0516.jpgIMG_0518.jpg
https://linustechtips.com/topic/359977-scrap-yard-build-help/
Do you know what pentium 4 that is? Some are 478 or 432, but some later ones are 775 which is needed for the e6600.
Updated 2021 Desktop || 3700x || Asus x570 Tuf Gaming || 32gb Predator 3200mhz || 2080s XC Ultra || MSI 1440p144hz || DT990 + HD660 || GoXLR + ifi Zen Can || Avermedia Livestreamer 513 ||
New Home Dedicated Game Server || Xeon E5 2630Lv3 || 16gb 2333mhz ddr4 ECC || 2tb Sata SSD || 8tb Nas HDD || Radeon 6450 1g display adapter ||
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4881127
The core duo runs on socket LGA 775 and the pentium runs on PLGA 775. No idea what the P means
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4881145
Hey, I'm real2end's techie friend who convinced him to build this pc.  I found out that it is an LGA 775 socket... but I sent him here to make sure a core 2 quad q6600 would work before he ordered it, also, what would be a good cooler for this?  Probably air cooling.
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4881147
@real2end & @gurnben
It's seriously a bad idea to use a Dell board. There is very little support for them, especially in the realm of BIOS updates. If this board held a Prescott Pentium 4, then I seriously doubt it will handle a Q6600 or any decent Core2Duo even. If its limited to an 800MHz FSB then it will most certainly not work with anything past an E4700.
Get me some details on the motherboard (ie: what Dell model it came out of, what CPU it has in it, even a motherboard model number) and I'll dig up info for you.
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4882300
thanks! That's what I was worried about, I figured we would find someone really knowledgeable here! We will look into a the mobo specs, but most likely, we'll probably just wait and save until @real2end has enough for a Pentium g3258, a decent mobo, etc. That way, there are no worries!
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4883457
here is the cpu what exactly do you need to know about the mother board
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4886935
That's a P4 521. 800MHz FSB. Guessing that setup is out of a... Optiplex GX520 or 620? Am I close?
That board won't run a Q6600. It predates them by about two years. Even if you could find a BIOS update to increase CPU compatibility the best you could probably get is maybe Pentium D's or possibly E4700s.
Not worth it.
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4887140
the mainbaord tab in cpuz will tell you what the board make, model, chipset and bios revsion. you should then be able to find out which cpu's are compatible from searching on google and dells website :)
Rig Specs:
AMD Threadripper 5990WX@4.8Ghz
Asus Zenith III Extreme
Asrock OC Formula 7970XTX Quadfire
G.Skill Ripheartout X OC 7000Mhz C28 DDR5 4X16GB
Super Flower Power Leadex 2000W Psu's X2
Harrynowl's 775/771 OC and mod guide: http://linustechtips.com/main/topic/232325-lga775-core2duo-core2quad-overclocking-guide/ http://linustechtips.com/main/topic/365998-mod-lga771-to-lga775-cpu-modification-tutorial/
ProKoN haswell/DC OC guide: http://linustechtips.com/main/topic/41234-intel-haswell-4670k-4770k-overclocking-guide/
"desperate for just a bit more money to watercool, the titan x would be thankful" Carter -2016
https://linustechtips.com/topic/359977-scrap-yard-build-help/#findComment-4887196
