I got abit of extra cash, and decided to finally get rid of my reference fans. I was planning on getting some noctua fans, and found out that some models where betters for different things. So should I use the nf f12s for my rad, and the nf s12s for the case intake and outtake?
https://linustechtips.com/topic/359975-noctua-fans/
Consider the Redux models, you get pretty much the same thing (in a nicer looking color imo) for noticeably cheaper, given you don't mind it not coming with some of the accessories.
"Rawr XD"
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4881094
That's what I use, seems to work good, though I haven't use any other fans on this rig, but it's pretty quiet :)
Case - NZXT H6 Flow : Mobo - ASRock X670E PG Lightning : PSU - Deepcool PX1000G : CPU - AMD Ryzen 9 7900X3D w/Arctic Freezer III 360  : Memory - G.Skill Ripjaws S5 32gb 6000mhz CL30 : GPU - MSI Expert 4080 Super : Storage - Verbatim Vi7000G 4tb NVME SSD  : Displays - Gigabyte 32" M32QC Curved 165hz & 27" M27Q Pro 165hz 1440p
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4881103
You seem to have the right idea. It might help to list your specs though.
They're not the same. Redux fans are older lines of fans.
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4881157
The rad is from an h100i, and the case is a corsair obsidian 450.
Rest of specs? The question was aimed more towards how much cooling would be necessary.
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4881181
i use a different case but I use the same cooler and the NF-F12s work great on it. and my NF-S12A's work good for pushing air in the case.
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4881189
If you have the money, check out these as well, they outperform NF-F12's on radiators.
http://www.performance-pcs.com/ekwb-fans/ek-vardar-f2-120-1450rpm-high-performance-liquid-cooling-fan.html
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4881469
nfs12a's are on sale at ncix (I'm in the us) ends soon!
http://www.ncixus.com/products/index.php?sku=79670&promoid=1413
LTT Community Standards                                               Welcome!-A quick guide for new members to LTT
Man's Machine- i7-7700k@5.0GHz / Asus M8H / GTX 1080Ti / 4x4gb Gskill 3000 CL15  / Custom loop / 240gb Intel SSD / 3tb HDD / Corsair RM1000x / Dell S2716DG
The Lady's Rig- G3258@4.4GHz(1.39v) on Hyper 212 / Gigabyte GA-B85M / gtx750 / 8gb PNY xlr8 / 500gb seagate HDD / CS 450M / Asus PB277Q
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4881819
I really hate Noctua's naming schemes and website layout. It is very difficult to discern which fans are better for static pressure and which are better for airflow without delving deeper and just looking at the raw numbers. All of their descriptions for every fan talk about using them for rads AND airflow.
I use NF F12s as case fans though :P I already had one for a rad I ended up not using, so I got two more. Cable management in the PC they ended up in is non existent, and I put them all inside a stocking as a makeshift dust filter anyway. Static pressure, whatever.
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4888245
They're all pretty straightforward with the naming scheme and description. Which are you confused about?
https://linustechtips.com/topic/359975-noctua-fans/#findComment-4890240
