most people have problems running gta V
most people dont have problems,
A minority does
Hey there. You are looking mighty fine today, have my virtual cookie!  :ph34r:
MY RIG: http://linustechtips.com/main/topic/34911-my-setup-gold-ghetto-gg-lots-of-pictures/#entry446883
So I now get this error. I was not getting this error before. Any suggestions? Crashes in-game when playing after about 5 to 15 minutes.
Most problems I've seen are for GTA Online.  I only ever get this error when playing GTAO.  40+ hours in single player and not a single error or crash.  10 hours in GTAO and at least 6 crashes so far.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
For me, 50 hours without this crash now I start getting this crash for no reason. I guess it's when they updated the game.
Congratulations, you now have to lower your gpu clock to be able to play the game without crashing.
If you are going to contact R* I suggest you tell them you have this problem and that you have..
Installed latest windows updates.
installed latest drivers.
updated steam.
lowered your gpu clock.
lowered your gpu memory clock.
updated the game to the latest version.
I also told them in the first message that my specs are...
gtx 980
i5 4690k
asus z97-a motherboard
8gb ram
1tb hdd.
That is everything they can ask you to do pretty much...although I did this myself
gtx 980
i5 4690k
8gb ram
1tb hdd.
And there reply to me after telling them all this was.
have you updated steam if you are playing the the steam version?
have you updated the game to the latest version?
have you installed the latest windows updates?
have you installed the ltest drivers for your gpu?
make sure i meet the minimum requirements.
I replied yes...I already told you what I have done and give you my specs in the first message I sent you.
R* then replied with...........Oh wait, they didn't reply after that.
But yeah, lower your gpu clock and it should work, which is an absolute joke to be honest.
My 197+ overclock has been stable for 6 months in all kinds of games, now I can't even have a plus 5 overclock wen playing gta.
Edit, evolve suffered with his exact same problem which was then fixed in a patch.
I7 4790K-----ASUS Z97-A-----GTX 1080-----CORSAIR H105-----CORSAIR VENGEANCE PRO 16GB-----ASUS PG278Q-----LOGITECH G900-----MASTERKEYS PRO L-----Sennheiser GSX 1000
updated steam.
gtx 980
i5 4690k
8gb ram
1tb hdd.
gtx 980
i5 4690k
8gb ram
1tb hdd.
Ok thanks for the info.
I see that you have got an GTX 770.
I've got a GTX 680, so very similar cards.
I got that screen as well after a cpl of days playing the game.
i found that turning V-Sync on the the graphic options helped for me.
Though now I can't get frame rates above 60fps. Seemed to be locked on the 60fps.
But now the game plays quite fine
i found that turning G-Sync on the the graphic options helped for me.
V-Syng or G-Sync on?
Wow, it works. Thanks!
This works? vsync on and you get no crashes? I may put my overclock back on an try this.
I think it kinda makes sense. You limit your fps, GPU doesn't work as hard, which results in more stability.
i7 9700K @ 5 GHz, ASUS DUAL RTX 3070 (OC), Gigabyte Z390 Gaming SLI, 2x8 HyperX Predator 3200 MHz
Great :) Glad to see it has worked.
There is also a choice of having "Half" V-Sync on.  Not sure what that means, & I haven't tried it yet.
Stupid works keeps getting in the way
Yep, weird.
Yeah, half Vsyn makes no sense ha ha ha...
Yep, weird.
Half Vsync limits the FPS to 30 instead of 60 if you have a 60hz monitor.
Only happens in sp for me,stutters in cut scenes and inside houses, sometimes crashes
fine on multiplayer tho
        Sample Text ( ͡° ͜ʖ ͡°)
Guest
