Hello guys!
So as you can read, im I busy with a new pc build.
This is my first time building, so please help me out. If there's something I forgot
(maybe even something that isn't right) or things that can't go together, please tell me!
I use this pc for especially gaming (CS:GO, ETS2, Cities:Skyline, G-Mod, etc)
My theme color is black/red
This is what i have in my mind:
Case: Corsair Graphite 780T Black/Red
CPU: Intel core I5-4690
CPU Cooler: The stock one which comes with the CPU.
Motherboard: MSI Z97 Gaming 5
Graphics Card: EVGA GTX 960
RAM: Hyperx Fury (2x4GB) Red
Hard Drive: WD 1TB
Power Supply: ????
Power supply: how much do I need?
* My budget is max. 1000
thankyou for reading!  :D
https://linustechtips.com/topic/359060-build-help-and-a-power-supply/
Good 500w-550w will do
Go with seasonic ones
like the s12ll 520w
Jonnyguru gives it a 9.7/10
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=185
Edited by xnoobftw
The BBQ: i7-4770 / 212x / Tri-X R9 290x 1075/1400 / MSI H87-G43 GAMING / EVGA G2 850W / Corsair Spec 03 / Samsung 840 EVO 250gb SSD / Toshiba 2TB HDD / 8gb Kingston DDR3 1600mhz
Peripherals: G710+ / G502 / Bose Companion 2 Series III / Audio Technica ATH-M40x / Sound Magic E50
Monitors: Dell U2414H
Ok nice! thankyou :D
Wait before that are you planning on SLI?
Not yet, but is bronze good? There are platinum power supplies too, right?
If you plan to you should probably get a 750 watts one
Yes so as long as it has a 80+ cert it is good!
Honestly speaking the difference in efficiency btwn bronze silver gold plat and titanium is not really all that great.....
Probably a few wattage difference pulled compared to actual wattage used in PC
Ok nice, you think a corsair would be fine ?
Go with evga g2 750 watts. I have the 850 watts version and jonny guru rates it near perfect (9.9/10)
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story6&reid=377
10 years warranty
semi fanless mode
Edited by xnoobftw
10 years warranty
semi fanless mode
A big thankyou for you my friend! Thanks for helping me out, i really appreciate it   :D
Is it a bit overkill if i just get it without SLI ?
You think it's better? Also, i have a limit off 1000, and i already have 950.
I could use it in further upgrades though
its usually cheaper than a 960
your next upgrade would probably be a 290x + a 750w or 850w G2
Which brand, and is it better?
of 280x or 290x?
in either case really the cheaper the better
BUT make sure you dont get a reference cooler
XFX and MSI are the best if you might watercool later on
otherwise sapphire and powercolor as well as everyone else is fine
just make sure its not a reference card
and yes its better
PSUs are one of the things to be okay with if you go overkill. Heck they are the most efficient when you use them at 50% load!
10 years of warranty to boot :P
  • 2 weeks later...
