Hello People.
I have decided to buy an external hard drive. The WD Passport, it has a USB 3.0 Connection interface. The laptop I am currently using only has UBS 2.0. Would it have compatibility issues using a downgraded version of USB?
Also, if you have or had this device, how was your experience with it.
Thanks.
http://www.flipkart.com/wd-my-passport-ultra-2-5-inch-1-tb-external-hard-drive/p/itmdqgvabhngtzyv?pid=ACCDQGVA2SWVFGCG&otracker=from-search&srno=t_2&query=external+hard+disk&ref=11bafb0c-8ae1-42ea-843a-411c16e8b424
https://linustechtips.com/topic/358372-external-hdd-usb-connection/
This drive have absolutely no problems under USB 2.0.
I have a friend who buyed exactly this one (1TB) and his mobo doesn`t even have usb3, so he is using it with usb 2 and there is zero problems. :)
ASRock Z97 PRO 4| i7-4790К@4600MHz/1.26V| Noctua NH-D14| 16GB ADATA@1800Mhz| Gigabyte GTX 660 WF OC| Samsung 840 Pro 128GB; Samsung 860 Pro 256GB; Samsung 860 EVO 500GB| Seasonic SS-650KM3 Gold| CM Storm QuickFire Ultimate| Mionix Naos 7000|
