ethernet switch and cables
Solved by minibois,
will a ethernet connector splitter " http://www.newegg.com/Product/Product.aspx?Item=9SIA74G2RC6307&cm_re=ethernet_splitter-_-0XM-004M-00003-_-Product" with 2 new cables be just fine for my pc and xbox one, or is investing in a unmanaged switch and new cables? i do plan on replacing my 5 year old ethernet cable already, and if a unmanaged switch is the way to go, my price range for a switch would be around 40.
I would personally invest in a gigabit switch.
Those are reliable and you have some extra ports that you can use for other devices.
I use this and it is really good (no complaints):
You can possibly get it cheaper somewhere else, I think I paid 22 euros for it.
Just be sure it's a Gigabit switch.
