So i built a gaming pc and when I started buying parts about 1 year ago I bought 16 gb of some cheap DDR3 ram at best buy and it just so happened to be kingston hyper x blu. When i bought my mobo about 3 months ago I just got the cheapest one that pc part picker said would not need a bios update out of the box and it was a asus m5a99fx pro r2.0. when I got it and looked at it I realized I did not think of color matching my parts but the m5a99fx is blue. But now I want a cpu cooler that matches my build the only thing i can find so far is this http://www.newegg.com/Product/Product.aspx?Item=N82E16835709002&cm_re=Phanteks_PH-TC14PE_Blue-_-35-709-002-_-Productand I was just wondering if you guys could suggest a different cooler that is also blue. I do not care if it is an all in one water cooler or costs more than this I just want a blue cpu cooler that works well and looks good. http://www.quietpc.com/asus-arctic-square When I saw this one I wanted it but it seems it is not sold anymore but if somebody could find one I would be forever in your debt.
https://linustechtips.com/topic/357698-cpu-cooler/
You could also consider the Prolimatech Megahalems Blue Series.
Intel Core i7-5930K | Noctua NH-D15S | ASUS X99-M WS | 32GB (4 x 8GB) G.Skill Ripjaws V 2666MHz | MSI GeForce GTX 980 Ti Gaming 6G | Samsung 850 Pro 512GB | Seasonic 660XP2 | Phanteks Enthoo EVOLV
LG 34UM95-P w/ Ergotron MX  | O2/ODAC | Audioengine A5+ w/ AS8 | Sennheiser HD 598 | Ducky Shine 3 | Cooler Master Storm Spawn
https://linustechtips.com/topic/357698-cpu-cooler/#findComment-4854210
What are you cooling?
https://linustechtips.com/topic/357698-cpu-cooler/#findComment-4854690
