Hey guys
I'm looking to build a pc in the coming months with about $1200 on me right now and with the 19th edition NCIX sales I wanna know if there is anything I can pick up.I don't need a GPU but please take into consideration that I want to have a good GPU.The reason I won't be building with a GPU is because there will most likely be a lot of sales with some GPUs due to some releases.So the total budget right now without a GPU is $1200.
I live in CANADA
The build should have a keyboard and mouse (Cheap),and I will pick up a 1440p monitor that isnt part of the build budget.
The max is $1200 without a GPU
https://linustechtips.com/topic/357550-need-a-quick-build/
Use of the build? What Software and Games?
Basic guide to CPU's!
If I said I were 14, you would call me a kid. If I say 70, you’ll entitle me too old. If I say 20 you say I’m inexperienced and if I say 40 than I'm too boring.
龴 ͡ↀ ◡ ͡ↀ龴#locked( ͡͡ ° ͜ ʖ ͡ °)
https://linustechtips.com/topic/357550-need-a-quick-build/#findComment-4851643
http://ca.pcpartpicker.com/p/NbTsCJ
IDK should I just build this or
Gaming
GTA V max 1440p
alot of AAA games basically
software is very simple for me I have 2 gb DDR2 and it is always enough but still 8 GB should be enough
Software like skype and browsing is what I do gaming will be new.
How much will the price drop be is it worth the wait?
https://linustechtips.com/topic/357550-need-a-quick-build/#findComment-4851720
