Well i got 2x hdmi one 1.4 and one newer 2.0probs but im getting a 144hz gaming monitor and a other 60hz for other stuff but i need help with what display thing should i get dvi hdmi? I will be using headphones monitor:benQ 3D LED XL2411Z
 Why would you get a monitor that doesn't support HDMI if you want to use an HDMI cable?
Build: GPU: MSI GeForce GTX 780 CPU: Intel i5 4690 MoBo: AsRock Fatal1ty H97 Killer RAM: Kingston HyperX Beast 16GB PSU: Seasonic 550W 80+ Gold Case: Corsair Obsidian 500R
https://linustechtips.com/topic/357327-144hz-csgo-gaming-help/#findComment-4849075
You can temporarily overclock your monitor with HDMI but I seriously only recommend this temporarily as I destroyed a HDMI (only because it was cheap others will last longer) by doing it.
Only do this while waiting to buy a dual link DVI.
Don't go above 120Hz as HDMI just flat up refuses but 120Hz seems fine.
https://linustechtips.com/topic/357327-144hz-csgo-gaming-help/#findComment-4849091
em i does so
Im not oc my monito i wanna keep it longer than 1year like 5yrs
Well im doin 144hz
If you OC your monitor to 75 Hz, it will still run longer than at 144Hz, your version of HDMI does not support 144 Hz.
My current build - Ever Changing.
Number 1 On LTT LGA 1150 CPU Cinebench R15
http://hwbot.org/users/TheGamingBarrel
https://linustechtips.com/topic/357327-144hz-csgo-gaming-help/#findComment-4849262
