Hello im looking for a good mother board that has a intel 1150 socket and is a good quality board i need it to be in the budget of $60-$120 AUD (Australian Doller)
Thanks
Overclocking or not? Preferred color scheme?
https://linustechtips.com/topic/357191-motherboard-help/#findComment-4847467
yes i will be overclocking but not straight away and colour doesnt really matter but i wouldnt mine some blue in it
This seems to be kinda over budget, but it is quality and features blue:
**Motherboard** | [ASRock Z97 Anniversary ATX LGA1150 Motherboard](http://au.pcpartpicker.com/part/asrock-motherboard-z97anniversary) | $129.00 @ Umart
| **Total** | **$129.00**
https://linustechtips.com/topic/357191-motherboard-help/#findComment-4847474
ill check it out
https://linustechtips.com/topic/357191-motherboard-help/#findComment-4847475
Quality hasn't been an issue for 1150 boards. Just find a board has the features you're looking for.
https://linustechtips.com/topic/357191-motherboard-help/#findComment-4854635
