Build for Architecture- Need Help
Go to solution Solved by g4m3cr34tor,
This should be fine for you
PCPartPicker part list: http://pcpartpicker.com/p/tcc2NG
CPU: Intel Core i7-4790 3.6GHz Quad-Core Processor  ($313.98 @ Newegg)
Motherboard: ASRock H97 Anniversary ATX LGA1150 Motherboard  ($74.78 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (1 x 8GB) DDR3-1866 Memory  ($51.99 @ Newegg)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($51.99 @ Newegg)
Video Card: PNY GeForce GTX 960 2GB XLR8 Video Card  ($182.99 @ Newegg)
Case: NZXT Source 210 Window ATX Mid Tower Case  ($44.99 @ Newegg)
Power Supply: EVGA SuperNOVA GS 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($70.98 @ Newegg)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit)  ($102.98 @ Newegg)
Monitor: Acer K242HL Bbid 60Hz 24.0" Monitor  ($120.98 @ Newegg)
Keyboard: Logitech MK120 Wired Slim Keyboard w/Optical Mouse  ($14.99 @ Newegg)
Total: $1030.65
You can also go with an R9 290 (https://pcpartpicker.com/part/sapphire-video-card-1003623l) for $50 extra
Hello I'm kind of new in the planning and building, never done one so this will be my first.
I will use this for school (I'm an architecture student) so I will be doing some rendering, CAD's, etc. but I would also like to use it for some gaming (Never really done it but looking forward to).
I been doing some research and I this is what I'm thinking:
CPU: i7 4790k (don't know if i7 or i5 is what I need)
GPU: GTX 960
Mobo: MSI Z97
RAM: 8GB
HDD: 1TB
PS: Antec HCG-620 M
I will also need to buy some peripherals:
-1 Monitor (preferably wall mounted)
- Keyboard (nothing fancy)
- Windows License
Im trying to stay around the $1000 USD (≈ $1,200 CAD), and I would buy  everything from eaither amazon or newegg.
Thanks in advance!
https://linustechtips.com/topic/357127-build-for-architecture-need-help/
Rendering will be faster if you go i7. You could also go AMD for that but nobody will recommend them here because the intels are better for single threaded workloads.
I cannot be held responsible for any bad advice given.
I've no idea why the world is afraid of 3D-printed guns when clearly 3D-printed crossbows would be more practical for now.
My rig: The StealthRay. Plans for a newer, better version of its mufflers are already being made.
You should be getting a i7 for such a work load. If you don't plan on overclocking, I'd recommend you get a 4790 or xeon equivalent and use the money you saved to get a better GPU.
Desktop: The Bluez | CPU: i5-3570k @ 4.5 ghz 1.296V | CPU Cooler: Hyper 212 Evo | Motherboard: P8Z77 M-Pro | Memory: 16 GB 1600Mhz Kingston HyperX
GPU: Asus GTX 780ti DirectCu II | HDD: Some Random Hitachi 1TB, WD Blue 1TB, 850 EVO 500GB | PSU: Rosewill Hive 750W | Case: Enermax Ostrog GT (Blue Ver.)
Laptop: Razer Blade 14 2013 256GB
Video Card: Sapphire Radeon R9 290 4GB Tri-X OC Video Card  ($239.99 @ Newegg)
Case: NZXT Source 210 (Black) ATX Mid Tower Case  ($39.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (32/64-bit)  ($69.99)
Monitor: Acer S220HQLAbd 60Hz 21.5" Monitor  ($99.99 @ Amazon)
Total: $1042.34
Generated by PCPartPicker 2015-04-29 01:49 EDT-0400
So you're shopping in Canada?
What's the scale of your average project?
Why a wall-mounted display?
Total: $1030.65
I live in mexico so I will be buying from US
I have been doing from residential up to mixed use so it ranges from small to big
Wall mounted so I can be working on my desk with other thing without the display getting in the way, but it's not necessary.
Can you give any examples of the work? That's still a bit less specific than I was looking for.
What desk do you have? A desk-clamping stand might be a more flexible option.
