Hey everyone,
I've got a GTX 570 right now and I want to upgrade to a 770 or even a 780.
Now the thing is, I'm only fine to spend that much money on a 780 if I can be more or less sure that it will last MUCH longer than a 770, in other words I won't be buying a Maxwell GPU when it comes out, in less than a year.
On the other hand I could buy a 770 and upgrade quite soon after Maxwell comes out if I have to.
What do you think ? Should I bet on the long term with a 780 or short term with 770 ?
Thanks for any help !
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/
Here's a review of the GTX 780. You'll see the 770 in there. You can use this to make up your mind. http://www.guru3d.com/articles_pages/msi_geforce_gtx_780_gaming_review,1.html
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456154
get a 770 with lots of vram and then SLI when the need comes. 780 only has 3gb vram, which is a must for 1080p gaming now, since 2gb isn't cutting it. 780 will get capped soon but 770 can SLI and it's $200 cheaper
Edit: I didn't mean that the 780 cannot SLI, because they both can, I meant that it will get capped with 3gb vram for multi monitor
There are 10 types of people in this world, those who understand binary, and those who don't.
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456197
Source? It also depends on what AA you use.
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456202
GTX 770 - better price per performance and more gram
System Specs - CPU: i7 4770K - RAM: 8GB(2x4GB) Vengeance Pro - Motherboard: Maximus VI Gene - Case: Modded PowerMac G5 - CPU Cooler: H100i - PSU: AX860i - SSD: Samsung 840 Series 120GB and Kingston V300 120GB - HDD: Seagate Barracuda 1TB - Graphics Card: 2x GTX 780 - Case Fans: SP120s and Spectre 140s - Headphones: HD700, Alpha Dog, SE215
Sony A7R w/ Zeiss 55mm F1.8
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456211
Proper name is VRAM. Unless it was a typo.
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456213
Yeah it was a typo
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456254
The 770 is the better value card. If you aren't set on Nvidia, the 7970 can be found for significantly cheaper with similar overclocked performance.
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456302
Get the GTX770 and then Maxwell.
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456311
The Arctic Demon:  i7 4770k | Asus Sabertooth Z87 | Swiftech H220 w/ NF-F12s | (2) Gigabyte Windforce R9 290 Crossfire | 16 GB Corsair Vengeance RAM | Corsair AX 850 | Samsung 840 500 GB | Corsair Vengeance C70 Arctic White | NZXT Hue
Peripherals: Logitech G600 gaming mouse | Cooler Master CM Storm Quickfire with Cherry MX Green Switches | QNIX QX2710 LED 2560x1440p PLS monitor | Logitech Rumblepad 2
https://linustechtips.com/topic/35625-need-help-for-a-new-gpu/#findComment-456727
