Where are temp sensors 4/5/6 on your mobo? Needs some fixing.
G3258 V 860k (Spoiler: G3258 wins)
i7-4790K | MSI R9 390x | Cryorig H5 | MSI Z97 Gaming 7 Motherboard | G.Skill Sniper 8gbx2 1600mhz DDR3 | Corsair 300R | WD Green 2TB 2.5" 5400RPM drive | <p>Corsair RM750 | Logitech G602 | Corsair K95 RGB | Logitech Z313
https://linustechtips.com/topic/355998-extremely-high-temps/#findComment-4832664
Your second core has a temperature of 10 degrees celcius, not even near your ambient temperature I think. Maybe you temperature sensor is broken, or you could check out another program like RealTemp. Maybe that one will give you some more realistic temps.
https://linustechtips.com/topic/355998-extremely-high-temps/#findComment-4832721
Lmao, m80 100 is far too high. I'd be comfortable @80 or under.
Sleepy: |  R7 1700@ 3.7GHz (NHD-15) | MSI B350 Tomahawk Arctic | GIGABYTE Windforce GTX 1080 | 16GB of RAM | 8TBs of HDD | 128GB SSD| S340 Tempered Glass | XFX 550w Bronze 80+ PSU | 40" 4K panel, and 3 1080p bois
https://linustechtips.com/topic/355998-extremely-high-temps/#findComment-4832726
LOL , NOOBS ABOUT . Those are fake temps , nothing in your computer is 100 C , it's just a temp sensor that's either not connected to anything or is broken . It's quite common . Had one in my pc that was saying -120 C , and another older one that was saying 999 C :D
https://linustechtips.com/topic/355998-extremely-high-temps/#findComment-4832737
The temps aren't fake. They are real, kinda. The mobo sensors are known to be bugged like hell. If you check temps under the CPU name, few rows lower, you can see that it sits pretty normal 43C idle.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/355998-extremely-high-temps/#findComment-4834837
My macbook hits 95C when gaming...
Just saying.
Also, I would assume those sensors are bugged. Don't trust them.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/355998-extremely-high-temps/#findComment-4835124
Get your hand in you PC and have a feel at any heatsinks.
You'll know when you find the culprit.
https://linustechtips.com/topic/355998-extremely-high-temps/#findComment-4836573
