So, I got my new build, everything but a good GPU. I am trying to twitch stream with a i7-4790k. However, I was streaming fine for a day or two, then suddenly, getting 50%+ dropped framerates on OBS and constant disconnects on Steam Broadcast... What could be causing this... My CPU isn't over heating, it's far from over heating, doesn't even reach over 60 C ever.
4790k
8gb ddr 1600
radeon hd 4750
msi gaming 7 mobo
850 pro ssd samsung
https://linustechtips.com/topic/354850-problems-live-streaming-with-new-build/
That graphics card is awful :(
Intel Core i7 7770K | 32 GB's Ram 3000MHz | GTX 1080 Ti | 250GB SSD | 3TB 7400 RPM | Sound Blaster Z | ASUS ROG MG278Q | Razer Blackwidow Chroma | Final Mouse 2015 | Blue Yeti | Seinheiser HD 600's | Beyerdynamic DT 990 Pro | Aune T1 MK2
HD 4750.........You must be streaming Minecraft :P
CPU - FX 8350 @ 4.5GHZ GPU - Radeon 5700  Mobo - M5A99FX Pro R2.0 RAM - Crucial Ballistix 16GB @ 1600 PSU - Corsair CX600M CPU Cooler - Hyper 212 EVO Storage - Samsung EVO 250GB, WD Blue 1TB
Um...
Why are you using a 4790k with a HD 4750?
Is your internet connection working as it was when everything was working fine?
I do not have the cash to afford a better gpu as of yet. I plan on getting a GTX 980.
And yeah, I don't seem to have any problems with my internet. 4.2mb/s upload.
The server you are streaming to can also cause dropped frames.  If the server is overloaded, your upload gets rejected resulting in dropped frames.  I just switch to a server in a different state/region and usually it's fixed.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
I've switched servers multiple times, and it's the same story for a few days now... I stream for a few seconds, and then suddenly all frames are being dropped. CPU is not stressed at all, not even over 50% usage on any core. And never gets above 60 C ever. I'm not really sure what is going on... I can't even Steam Broadcast without people getting disconnected.
