triple monitor for gaming ?
tsukasa
hai mate, wanna know triple monitor or single monitor is worth for gaming? &  almost forgot wide screen monitor
i need ur opinion mate
IMO 21:9 monitor is best experience, it's cheaper and less performance hungry.
mate
CPU: i7 - 2600kGPU: GTX 1070Mobo: intel somethingRAM: Corsair XMS3 @1600Mhz (8GB)SSD: Crucial MX100 256GB. HDD: WD Green 1TB . Case: Cooler Master HAF XB EVO Monitors: LG 25UM65-P and Benq 2200HD Keyboard: Corsair vengeance K70 FPS Red switch. Mouse: Logitech G502 Proteus Core. Headset: Steelseries Siberia V2
hard to power, fps games seem to enjoy stretching themselves only useful for a quick warning something is coming at you in what would be off screen but unlike car mirrors objects in side screens are further then they appear.
didnt enjoy it for racing since my dashboard was bent which was odd to say the least.
Thus far ive preferred a single monitor and track IR to be honest, and use the 2 side monitors for skype and whatever else..that being said at times I will still power all 3 for some games.
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
@tsukasa u wot m8? lol
inb4 21:9 is the most cost-effective way for gaming on a wider screen compared to using 3 monitors. Plus no bezels :3
but if you do a lot of multitasking, editing or programming a triple monitor setup would be better.
If you're thinking of going competitive E-Sports Playing on a single screen rather than surround is better since Competitions only use 1 monitor(if its 120hz+ it's even better)
|CPU: Intel i7-5960X @ 4.4ghz|MoBo: Asus Rampage V|RAM: 64GB Corsair Dominator Platinum|GPU:2-way SLI Gigabyte G1 Gaming GTX 980's|SSD:512GB Samsung 850 pro|HDD: 2TB WD Black|PSU: Corsair AX1200i|COOLING: NZXT Kraken x61|SOUNDCARD: Creative SBX ZxR|  ^_^  Planned Bedroom Build: Red Phantom [quadro is stuck in customs, still trying to find a cheaper way to buy a highend xeon]
I prefer running my games in triple monitor, even though I'm only using a single GTX 970. And like others said, they do tend to stretch FPS games, but its still useful because you can see more than one door if you'r camping an objective etc. Just flicking your eyes back and forth between the monitors looking for threats.
It does put out some heat into your room though. And a single 970 is not quite enough, I can run battlefield hardline on high settings with about 57-ish frames per second. GTA 5, I can run at high at about 30 fps, and ESO I can max everything out and sit comfortable at 60. (my monitors max at 60)
Dubs are better than subs
owh i see , tq mate now i know wht is best for my beast to play
  • 4 weeks later...
