PROJECT KALTE
So, where shall I start. Well, this is my most expensive, money-wasting, and ambitious "investment" I will most likely ever do. I will be constructing a full custom water cooling loop. The loop includes a Gigabyte GTX 970 G1 Gaming, and an AMD FX-8320 (Yes, I will upgrade to an i7-6700K when it comes out). This will all be housed within my Corsair Vengeance C70 Fractal Design Define S case. Although some modding will be required to fit in the two 360mm radiators I have planned. The total cost of this loop will be $700. I will be saving up my precious paychecks over the course of about 2 and a 1/2 months. So, without further a do, here is the parts list I have planned. Since this is my first loop ever, I may not be the most educated on this topic, but I've done my best to do my research online. If you have any tips, please feel free to drop them, and  I appreciate any feedback.
CPU Waterblock: EK-Supremacy EVO - Acetal+Nickel RECEIVED
GPU Waterblock: EK-FC970 GTX WF3 - Acetal+Nickel RECEIVED
GPU Backplate:  EK-FC970 GTX WF3 Backplate - Black RECEIVED
Case: Fractal Design Define S RECEIVED
Radiators: 2x Alphacool NexXxos ST30 Full Copper 360mm RECEIVED
Pump/Res: XSPC Photon 170 D5 Vario RECEIVED
Fittings: x10 EK-ACF 12/16 (7/16 ID & 5/8 OD) - Blue RECEIVED
Tubing: PrimoChill PrimoFlex Advanced LRT 12/16 (7/16 ID & 5/8 OD) - Clear RECEIVED
Fluid: Mayhems Pastel Blue Berry RECEIVED
Fans: x6 Noctua NF-F12 iPPC 2000 PWM (Already have 2) RECEIVED
Lighting: NZXT 2-Meter White LED Strip Sleeved RECEIVED
CPU: Intel Core i7-5820K ORDERED
RAM: Corsair Vengeance LPX 16GB (4x4 Blue) ORDERED
Motherboard: ASRock X99 Extreme6 ORDERED
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
https://linustechtips.com/topic/353977-project-kalte/
UPDATE I
So I went ahead and ordered some things for my planned loop. Since I'm going to be modding my C70, I will need to remove my drive bays, and my current lighting is an NZXT Hue, which requires a 5.25 bay, so I went ahead and ordered a 2 meter white LED strip from NZXT. The NZXT Hue doesn't produce a perfect white light anyways, which is all I want. I also ordered four Noctua NF-F12 iPPC 2000 PWM, since I'll need six for my planned two 360mm radiators (I already have two). Also, ignore the Warning from ASUS Suite, I have a faulty tachometer :P
https://linustechtips.com/topic/353977-project-kalte/#findComment-4817041
  • 2 weeks later...
UPDATE II
My original was to just mod my Corsair C70, but I just fell in love with the Fractal Design Define S, so I went ahead and pulled the trigger on it.
https://linustechtips.com/topic/353977-project-kalte/#findComment-4927081
  • 5 weeks later...
UPDATE III
So I'm super glad to say that I have placed the order on my complete water cooling loop. The grand total was $718.99, not including previous purchases, such as fans and case. I'm not sure when it'll get here but I'll certainly post pictures of the process. The next week or so are going to be long.
https://linustechtips.com/topic/353977-project-kalte/#findComment-5173720
UPDATE IV
So all of my water cooling parts arrived today, I was extremely excited and could barely finish writing my signature for the FedEx guy. It was a rough and stressful journey, but in the end I made it. I present you my first ever custom loop, it looks pretty ugly but it is my first time, some angled fittings would've made it cleaner, but I'll leave that for next time. The pump res combo was a lot bigger that I thought (TWSS), as well as the CPU block, and the GPU block is heavy. The most frustrating part was mounting the top radiator, 0/10 would not do again. I absolutely love the pastel aesthetic of Mayhem's fluid. So here are some pics of the process, well not really, but I took pictures of all of the components and my finished result. I hope you enjoy.
Here is my PC completely disassembled before the parts arrived.
Here is the box of all the components, the FedEx guy might as well have been Santa Clause.
CPU & GPU Block Packaging
GPU Backplate Packaging
Pump / Res Combo Packaging
Tubing Packaging
Fittings Packaging
Two Radiators
GPU Block Installed
GPU Backplate Installed
CPU Top
CPU Bottom
CPU Block Installed
Pump / Res Combo
Two Radiators
Semi-Assembled
Final Product
Final Product 2
https://linustechtips.com/topic/353977-project-kalte/#findComment-5206294
Thats pretty Cool! (get it? Cool cause of the... temps.. no?... ok... )
Only thing I would have done differently is the triple dual rad. Bit overkill... but hey, you can never be too cold.
https://linustechtips.com/topic/353977-project-kalte/#findComment-5210478
Awesome build, very clean and not overdone with the blue. I love that mobo in a blue build, it looks great under that lighting. What is that in your last PCI slot? Sound card? Also triple top rad for me was also 0/10, lol.
https://linustechtips.com/topic/353977-project-kalte/#findComment-5213514
MY GOD MAN!!! That is amazing! I probably would have gone for a different color of coolant in order to accent the blues more, but seriously man great job on the work, and I'm sure that anyone who sees this will be amazed and question how you did that :)
https://linustechtips.com/topic/353977-project-kalte/#findComment-5215236
  • 3 months later...
UPDATE V
I am happy to announce that I have placed an order on the following items as a pretty major upgrade to my build.
  • Intel Core i7-5820K
  • ASRock X99 Extreme6
  • Corsair Vengeance LPX 16GB DDR4
I never though I would have an X99 system, so I'm really can't wait for my parts to arrive.
https://linustechtips.com/topic/353977-project-kalte/#findComment-6092342
