Ok i have posted the system bellow , with all custom prices and everything.
I will play games like GTA V, Far cry 4, Just Cause 3 e.t.c.
~Should i change any parts?(Can't go more expensive)
~Is the GPU(series) good?
~Is the motherboard sufficient for the OC'd GPU ????
~Should i add a CPU fan(i think it's not necessary since i am not overclocking )
~Does the case have good airflow?
~Is this a good price?
Thanks in advance!
http://it.pcpartpicker.com/p/BgBHD3
https://linustechtips.com/topic/353209-help-with-gaming-build/
It's a decent build.  No idea about price since I don't use Euros :P
I'm also pretty sure there will be many comments regarding the GTX 960 :P
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800462
Thanks in advance!
Get rid of the gtx 960 and get a r9 280 in stead.
An AMD cpu has no place in a solely gaming build, end of.
I3 4150, Intel HD graphics, corsair CX750M, 4gb ram, Asus H81M-E, corsair 230T, Intel stock cooler WD Green 2TB Gigabyte 550TI
Why you shouldn't trust Gpu or Cpu boss Click on this I dare you!
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800466
-snip-
Yeah, that's good.
But what is your budget? Do you have the headroom to throw in an SSD?
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800472
The prices are pretty good. Usually they are higher (at least where I live..)
And yeah, there was already a 960 vs. 280 comment..
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800482
ΗΜΜΜ Α friend of mine says that r9 280 is better , but how do you justify it :/ ?
The R9 280 has 3GB of VRAM versus the GTX 960's 2GB.
This can be quite helpful in some games. Other than that, the prices are sometimes lower for that AMD card for about the same performance.
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800492
Every time some body makes a build with a 960 in it there is always some one commenting that stuff isn't there. B)
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800498
Oh man i love SSDs , i got a samsung 840 PRO couple of years ago and it saved my aaarse! Now build is for a friend , he will probably add one later on.
If he will add an SSD later, the Blue drive is ok.
If he was not going to add an SSD later, the WD Black might be good since that drive is so fast :)
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800523
What series exactly do you guys suggest?
Gigabyte, and msi are very good choices.
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800526
Could you guys suggest a Z97 mobo around the same price and maybe a little more(Preferably : MIN: 4 SATAs and 4 RAM Slots (wouldn't mind 1600 MHZ) and (not necessary) but maybe?SLI/Crossfire? )??? I heard it is best if i have a Z97 :P .
The good brand for AMD graphic cards are Sapphire, MSI, Gigabyte, ASUS.
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800607
You are not getting a K series CPU, so getting a Z series motherboard is pointless :P  You can't overclock anyway, so don't get a Z mobo (overclocking mobo).
https://linustechtips.com/topic/353209-help-with-gaming-build/#findComment-4800623
