Need help with PCI!
Go to solution Solved by ApolloX75,
From what I can find PCI is listed as PCI. If a site is listing PCI X16 then I would err on the side of caution and assume they mean PCI-E and are just lazy.
I need a Riser Card/extension cable for my soundcard that uses PCI. I could only find one single product in my country that I can buy, but I am confused if it's the right part.
I can't seem to find any info on a PCI x16 lane, only on PCI-E which I can't use, so I'm wondering if it's a typo on the webpage or if PCI x16 actually exists and is just a normal PCI lane.
So can anyone tell me if this Riser Card will work, or if there's something wrong with it? (see pictures)
Webpage: http://www.digitalimpuls.no/PC-komponenter/Kabler-og-adaptere/Riser-kort/PCI/OEM-Riser-card-PCI-x16--15-cm---ideelt-for-sm%C3%A5--trange-kabinetter-127411-p0000081484.aspx
Motherboard: http://dlcdnet.asus.com/pub/ASUS/mb/LGA2011/P9X79-LE/E8039_P9X79_LE.pdf
post-130422-0-18963200-1429727995_thumb.
post-130422-0-78427700-1429727999_thumb.
https://linustechtips.com/topic/353157-need-help-with-pci/
The New Machine: Intel 11700K / Strix Z590-A WIFI II / Patriot Viper Steel 4400MHz 2x8GB / Gigabyte RTX 3080 Gaming OC w/ Bykski WB / x4 1TB SSDs (x2 M.2, x2 2.5) / Corsair 5000D Airflow White / EVGA G6 1000W / Custom Loop CPU & GPU
The Rainbow X58: i7 975 Extreme Edition @4.2GHz, Asus Sabertooth X58, 6x2GB Mushkin Redline DDR3-1600 @2000MHz, SP 256GB Gen3 M.2 w/ Sabrent M.2 to PCI-E, Inno3D GTX 580 x2 SLI w/ Heatkiller waterblocks, Custom loop in NZXT Phantom White, Corsair XR7 360 rad hanging off the rear end, 360 slim rad up top. RGB everywhere.
https://linustechtips.com/topic/353157-need-help-with-pci/#findComment-4799759
That's what I thought :( The only problem is that then I have to order from ebay and it's gonna take a month to ship it :P
https://linustechtips.com/topic/353157-need-help-with-pci/#findComment-4799770
You can also look at the connector if there is an image of the riser and determine from there. PCIE and PCI have different notch sizes and at different places.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
https://linustechtips.com/topic/353157-need-help-with-pci/#findComment-4799773
I would if there was a picture, sadly there isn't. I tried googling it, but it was so many different pictures and I can't reliably see if it's PCI or PCI-E.
https://linustechtips.com/topic/353157-need-help-with-pci/#findComment-4799822
I would say for the most part they will be PCIE risers as they became in demand during the cryptocurrency craze.  I know, cos I have a few of them lying around lol.
https://linustechtips.com/topic/353157-need-help-with-pci/#findComment-4799836
Yeah, most likely... Looks like I'll have to order from ebay and just wait a whole month :/ Thanks anyway!
https://linustechtips.com/topic/353157-need-help-with-pci/#findComment-4800481
