Crazy CPU Clock-Speed! HELP!
Go to solution Solved by blu4,
It just stared yesterday, my FX-6300 always remains above it's stock clock-speed [3.5 Ghz]. I'm also using CM Hyper 212X.
The FX-6300 has a 4.1GHz boost clock. Don't worry- this is normal.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
Oh, but I'm doing anything. It's just idel....
It's nothing to be worried about, it also may be task manager being stupid because it always misreads my 4.6GHz overclock as 6GHz so..
Windows is making sure you got all those jigahertz :P
Previously Trogdor8freebird
5800x | Asus x570 Pro Wifi (barely enough for 64GB apparently given it's 2133 and still crashes sometimes) | 64GB DDR4 | 3070 Ti 8GB | Love that whole weeb shit
