Before 350.12, I was able to use DSR and play games in 4k or 1440p with my GTX 780. Right after the update, I lost that ability. I cannot use DSR within GeForce Experience or my games. Did Nvidia do this purposely? Does anybody else experience this? Please let me know.
https://linustechtips.com/topic/352741-geforce-35012-removes-features/
As far as I know, you can still use DSR on any (well mostly the higher end) 600+ series card.
The Rig: NZXT H440 M3 (Green and Black) (Ncase M1 coming soon!!) | Intel Core i5-4690k x BeQuiet PureRock Slim | EVGA GTX 1060 6GB SSC  | ASUS H81i Plus | 12GB EVGA SSC @ 1600MHz | Seagate Barracuda 2TB | Sandisk Ultra II 480GB | Corsair SF 450| LG 29" Ultrawide | CoolerMaster Quickfire Rapid TKL | Corsair M65 Black Sennheiser HD 558 (MOD) | Audio-Technica ATR 2500
It can be found in NVIDIA Control Panel.
Tried that too. Doesn't work, either.
Really? It appears for me.
Ok well it shows up for the resolution in general. But, it doesn't let me use DSR with any games if you go to program settings. Also, what card are you running?
I'm running a GTX 970 with a 660 Ti. I just select the resolution manually in the games.
Well it's weird because before the driver update I was able to use DSR as I should. I have a feeling that Nvidia is making you buy 900 series cards. Did I just uncover a conspiracy!?!?
Probably just a bug
i5 2400 | ASUS RTX 4090 TUF OC | Seasonic 1200W Prime Gold | WD Green 120gb | WD Blue 1tb | some ram | a random case
Do a clean driver install with DDU.
I'm seeing this complaint elsewhere. Its likely unintended, but if not that would be a dick move by nvidia.
R9 3900XT | Tomahawk B550 | Ventus OC RTX 3090 | Photon 1050W | 32GB DDR4 | TUF GT501 Case | Vizio 4K 50'' HDR
If that's true, why am I able to use DSR just fine and why is it still appearing for you? (I know it's the NVIDIA Control Panel, but it's usable)
Your card is based off of Maxwell and mine is Keplar. Nvidia never truly supported DSR for the card.
What you're experiencing is probably a bug(or user error). The 500, 600, 700, and 900 series can all utilize DSR.
