overall happy with the outcome of this build. What do you guys think of this build?
CPU: Intel Core i7-4790K 4.0GHz Quad-Core Processor  ($326.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($28.89 @ OutletPC)
Motherboard: ASRock Fatal1ty Z97X Killer ATX LGA1150 Motherboard  ($121.98 @ Newegg)
Memory: Kingston Savage 8GB (1 x 8GB) DDR3-1866 Memory  ($64.99 @ Amazon)
Storage: Samsung 850 EVO-Series 500GB 2.5" Solid State Drive  ($198.61 @ Amazon)
Video Card: Zotac GeForce GTX 970 4GB AMP! Extreme Core Edition Video Card  ($373.98 @ Newegg)
Case: Thermaltake VN10001W2N ATX Full Tower Case  ($159.99 @ Newegg)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($61.98 @ Newegg)
Optical Drive: Asus DRW-24B3ST/BLK/G/AS DVD/CD Writer  ($21.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit)  ($86.89 @ OutletPC)
Total: $1446.28
https://linustechtips.com/topic/351837-updated-build/
Total: $1446.28
you could go as low as 500w , but 550w / 650w should be fine ( unless you upgrade the 970 to a 290x , then you would need ~550-600w )
Recommend what is best, not what you preffer.
"Like" comments to show your support of them or the idea they express.
https://linustechtips.com/topic/351837-updated-build/#findComment-4783602
I doubt that you need that i7 but its pretty good , I would get 2x4GB RAM,No HDD ?
CPU: Xeon 1230v3 - GPU: GTX 770  - SSD: 120GB 840 Evo - HDD: WD Blue 1TB - RAM: Ballistix 8GB - Case: CM N400 - PSU: CX 600M - Cooling: Cooler Master 212 Evo
Update Plans: Mini ITX this bitch
https://linustechtips.com/topic/351837-updated-build/#findComment-4783609
Yeah ;
but his entire build is a bit over kill , you don't need a 120$ mobo or a 500gb SSD
BTW , PLEASE don't buy windows , go on reddit / teksyndicate forums and get it there for 1/5 of the price ( and these are legal )
https://linustechtips.com/topic/351837-updated-build/#findComment-4783655
That PSU should be fine. Like what others have said, you can go to 500W if you wanted. I believe XFX makes good power supplies too, so you're set.
What I'd think about changing are: Motherboard and RAM. That motherboard is fine, but I've heard better things about other ones at around the same price (ex: Asus Z97-A, MSI Gaming 5, etc). Unless you plan on upgrading the system to it's maximum, 32GB, you'll be better off getting a dual channel, 2x4GB set. Also, of course, if you're just gaming, go with an i5 4690k instead.
https://linustechtips.com/topic/351837-updated-build/#findComment-4783664
Yeah ;
do you have a link for me to find Windows off reddit
https://linustechtips.com/topic/351837-updated-build/#findComment-4784079
grabbing a 500gb ssd, should i get a hdd on top of that
With games getting bigger and bigger yes
https://linustechtips.com/topic/351837-updated-build/#findComment-4784093
the asus mobo is 20 dollars more and the msi is 10 dollars more, i do like that msi mobo tho,
https://linustechtips.com/topic/351837-updated-build/#findComment-4784099
whats the point of having a ssd and a hdd? should i just get a 1tb ssd instead of 2 separate storage units?
SSD for OS and all small applications, HDD for those 60GB games, or just as a place before deleting
https://linustechtips.com/topic/351837-updated-build/#findComment-4784117
so im better off getting like a 250gb ssd and a 500-1tb hdd?
thats kinda the standard yes
https://linustechtips.com/topic/351837-updated-build/#findComment-4784141
Yeah ;
you have a link i could find this at?
https://linustechtips.com/topic/351837-updated-build/#findComment-4785420
https://linustechtips.com/topic/351837-updated-build/#findComment-4790676
