Question about cooling Fractal Design Define R4/R5
By
Guest
in Cooling
in Cooling
Solved by GodSpoon,
You should be fine without SP (static pressure) optimized fans.
I would look into the Noctua NF or NH series if you want stupid quiet fans, as well as BeQuiet and Aerocool
If your doing watercooling or will have more obstructions I would look into the Noctua fans I mentioned, Corsair's SP series and the new Vardar fans I saw floating around from EK
Featured Topics
Rogers24 ·
Posted in Troubleshooting0 -
TurkishBTW ·
Posted in Peripherals0 -
1
kennethk ·
Posted in Peripherals1 -
4
BTSHalfLifeAndGmodFan2003 ·
Posted in Storage Devices6 -
6
1
Abaris ·
Posted in Troubleshooting4 -
2
