I need Help
Go to solution Solved by Tedster,
You change the export settings in Vegas and export to MP4...
This video should help:
I tried making a Youtube Video which i managed to but the final file which i have rendered is in mxf format. i cannot convert it into mp4 as all softwares are paid. What do i do??? Youtube does not accept mxf file.... I use Sony Vegas
Get your original project and render it correctly?
Or throw that mxf file into Vegas and render it in a proper file type?
https://linustechtips.com/topic/351018-i-need-help/#findComment-4773403
