A few problems on my PC.
By
Fortress
in Troubleshooting
in Troubleshooting
Solved by minibois,
-snip-
Problem 1:
Have you tried taking the Hitachi drive out of the system and plugging in the WD drive that in the SATA port that HDD used? I kind of feel like that might it the problem.
Problem 2:
Not sure what the problem exactly is, but it is probably not good that you have to insert your GPU all the time.
Is this with the same PC or not?
l3eyond ·
1
Serendipity1344 ·
Posted in Graphics Cards4 -
1
1
5
1
toxic_worper ·
18
