Overheating VRMs
Solved by SkilledRebuilds,
Tomb Raider gave VRM temps of 85C on the back card and 70 on the front card. No where near as bad as it was in Kombustor, but the 85C is still fairly toasty. Interesting MSI advertises a program on the box that runs like crap on the card.
That actually seems about normal now...srsly.
It's only 85*c on top because of the lower card under it feeding it hotter air...
The 75*c vrm temp on the bottom card is normal.
All seems normal.
/Using Furmark/Kombuster products will only make your heart drop,.. use programs YOU would use in an everyday sense of testing...
Games/Encoding/Whatevers....
