Help picking a CPU
Go to solution Solved by SeanAngelo,
i'd say a 4690k if you can stretch your budget that far.
EDIT: just searched up but your motherboard is H97 right? if you wanna overclock then i suggest you get a Z97 motherboard.
Hi guys,
I am building a new gaming rig, and I'm having a little trouble choosing the CPU. I want a 'Bang-for-the-Buck' CPU, preferably Intel (I know I shouldn't shop by brand but this is what I am comfortable with), for an 1150 socket.
These are the parts I have selected so far.
CPU: Intel i5-4460
GPU: ASUS GTX760 (DC2OC 2GBD5)
RAM: 2x4GB DDR3-1600 CL11 from GeIL
PSU: Chieftec IArena GPA-450B8 (450W)
MOBO: gigabyte G1.sniper H6
And I already use a Samsung 850 EVO 250GB SSD as a bootdrive.
I've already got the GPU and the power supply installed in my current rig, so changing that is no real option. And I would like to be able to upgrade this system (one part at the time) in the future, so:
1. Should I get a K or X version of a CPU for overclocking in the future?
2. What model is recommended compared to my other components?
Keep in mind that I am on a budget, and I'd like to stay close to the price of the i5-4460.
 - J0kador
https://linustechtips.com/topic/350086-help-picking-a-cpu/
Hi guys,
CPU: Intel i5-4460
 - J0kador
What is your overall budget for the build? For the price, you can't get anything better than the 4460
https://linustechtips.com/topic/350086-help-picking-a-cpu/#findComment-4762837
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/350086-help-picking-a-cpu/#findComment-4762840
a 4670k would be a great choice
Case: Phanteks Evolve X with ITX mount  cpu: Ryzen 3900X 4.35ghz all cores Motherboard: MSI X570 Unify gpu: EVGA 1070 SC  psu: Phanteks revolt x 1200W Memory: 64GB Kingston Hyper X oc'd to 3600mhz ssd: Sabrent Rocket 4.0 1TB ITX System CPU: 4670k  Motherboard: some cheap asus h87 Ram: 16gb corsair vengeance 1600mhz
https://linustechtips.com/topic/350086-help-picking-a-cpu/#findComment-4762854
Thank you,
I think I can stretch my budget this far, I will also look into a Z97 motherboard.
You have been really helpful.
https://linustechtips.com/topic/350086-help-picking-a-cpu/#findComment-4762861
