hi everyone ....
i have a problem .. since i played gta iv for one hour and the PC shut down itself when i open it again then this screen appears
when windows  start
this is the temp in IDLE , the resolution locked to 640x480 and when i try to  increase it , this show me
my card is ASUS GTX 780 DCUII
​i changed the driver and nothing happened
please if any one have the experience , tel me what shold i do >>> sorry for bad english
https://linustechtips.com/topic/349771-gtx-780-big-issue/
You've got a crispy card. RMA it.
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4758833
Remove the card and try using integrated graphics and try reinstalling drivers, if the issue persists then you probably need to RMA.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4758835
why this happened ,  is there some thing wrong with the power supply or the issue from the card it self ????
It was  definitely the card that was faulty i didn't have a very heavy over clock on it nor did i over volt it so im not sure why it happened. So you'll have to return it.
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4758872
RMA = Return Material Authorization which means send it back to shop/factory.
Your card basically managed to break the VRAM, this can happen because of weak soldering points, bad memory chip, many other things I'm sure.
You can't repair this, there is a 3 year warranty on this card so good luck!
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4758876
i will return it , i have question please : how can i know if my power supply have overvoltage ??
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4758888
i purchase this thing from amazon usa four month ago , is there return policy ?? is there cost from me shiping the card to amazon ???
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4758902
You able to over volt with any power supply really but you use over clocking software to tell the component (such as gpu or cpu) to use more power so you can get a stable over clock. Hope this helps.
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4758928
I have no experience with shops other than Dutch ones, but Asus Support has been really nice for me...
You can try that (Google is your friend I'm sure)
https://linustechtips.com/topic/349771-gtx-780-big-issue/#findComment-4759291
